1 - 6 of 6 Posts
I've got new pads and rotors, have the bracket off, the rotor screws out, but the rotor is stuck to the hub. I've applied pb blaster, but still won't pull off by hand/rubber mallet. I've seen threaded holes in other bmw rotors to pop them off, but there are dowels in these holes. What should I do? Thanks.
Use the rubber mallet to hit the disc near the edges towards the car (rather than from the back). Keep hitting different places around the disc and it will eventually pop off.
Its stuck because the previous discs were probably put on with some kind of grease which isn't needed. Once its off, clean the hub surface well and the next time it should be much easier.
Thanks guys...got it! two taps with the bfh on the face and it popped right off. Second hand caught it..leaving screw in is a bright idea. Centric premium rotors and Padgid pads going on. See about these rotors...china:/
1 - 6 of 6 Posts
