1 - 16 of 16 Posts
I'm having a very strange problem with my 01 M5. When I accelerate quickly in gears 3 and above the rpm's rise rapidly, like you were holding in the clutch, but the car isn't going any faster. It's fine if I accelerate slowly. It's only when I punch it and it happens around 4500 RPMS. It started right after I mistakenly downshifted from 4th to 2nd. Not sure if that did it or it was already there. There are no warning lights on. Anyone have any ideas??? I can't get into the dealer until next Wednesday. Thanks.
Ed
Your clutch is slipping...a common M5 annoyance. Do a search for it and you'll find a ton of posts about similar problems. I had mine replaced under warranty...you may need to do the same.
:cheers:
Banned
I just started having the same problem....we'll see if BMW replaces it...if not say hello to UUC stage 3
Yup, like the others said it is your clutch. I just had mine replaced last week with the UUC Stage 2 Kit, if you can afford this option, it's worth it.
2nd 3rd and 4th that. It's a bad clutch. Dealer replaced mine under warranty.
ard said:
Uh, I'd leave that part out of the explanation when I spoke to the dealer....
A
LOL, exactly my thoughts on the matter!
If there ever is a rise in rpm's without a rise in car speed, you have a clutch issue. Unless that is if you are using the power to spin the back tires... :haha:
:cheers:
Thanks all. I appreciate your input and yes I'm sure it is a clutch problem. My M5 is a certified 01 with 54,000 miles. Do you think this will be covered under warranty or is this a wear issue? Thanks again for all the replys.
Ed
It depends on when it was last replaced, and more likely the mood of your SA. If he feels like replacing it, he will, but I think you'll just have to go down and find out. If he wont replace it, it might be time to pony up a few extra dollars for a good UUC setup, as even though it will cost more money than an OEM clutch, you'll save money in the end by not replacing it like crazy.
:cheers:
So what is a "problem" in your book?
:1: :1:
(I know, a figure of speech- but it struck me funny.)
A
PS 54k on the original clutch is pretty good- that MAY factor into the need for a UUC set up... if your driving would only give you 20k on the clutch, the UUC may be worthwhile... but getting another 50k out of a stock might make it a harder decision....
Well, it would have become a "problem" had my Service Advisor" given me a hard time about replacing it under warranty. :haha:
Fortunately, he has been very helpful and I had no problem getting it replaced under warranty.
:cheers:
bayerischemotor said:
Lot of clutch problems in the US...
Very little in Europe... Atleast what I know of.
Well THAT'S interesting...
Nature or Nurture?
Genetics or Environment?
US drivers used to automatics OR Different Builds in EU?
Hmmmm
Banned
I did some research on M5 clutches and the SPEC stage 3, 9.5" billet plate clutch kit
(#sbd633) with the lightened dual mass flywheel (#sb63dml) is the best setup with no rattling
noise....all for $1268+install....no dealers but SPEC directly carries this model
Nature or Nurture?
Hmmmm
Maybe you just drive harder?
Or could there be any truth to the automatic gearbox use? hmmm
No it's gotta be genetics :noSMG:
1 - 16 of 16 Posts
