Good Advice.Unless you're going to drive it around long enough to get up to full operating temperature, it's better to put a trickle charger on it and let is sit for the 3 to 4 months. Repetitive "dry starts" are not good.
Agree. Another reason to not start it unless it's going to get up to temp is to avoid condensation on the cylinder walls.Unless you're going to drive it around long enough to get up to full operating temperature, it's better to put a trickle charger on it and let is sit for the 3 to 4 months. Repetitive "dry starts" are not good.
Not recommended only if you take a car for real ride for at least 1/2 hour. If you start your car for 15 minutes you will destroy the engine by creating a lot of heavy deposits in your engine. If you like to take it out for a drive you should do it at least once a month.Is that alright to do or should I just start it every 3-4 days?
