1 - 20 of 28 Posts
Hello, I just got a 2006 M5 earlier this week, 87k miles, everything inside works perfectly except for the steering column adjustment and it's stuck fully up.
I took the under dashboard cover off and did some diagnosing. INPA shows that the little switch in the column is working, i see signals for all 4 directions. When I check the wiring at the motor though I'm not getting any volts at all.
I checked the fuses i could think of, 71 in trunk and 2 other fuses which power the central body module just in case. they're all fine.
I can't find any information on this issue anywhere and any help is greatly appreciated.
Can anyone point me to ecu controls the steering column in inpa?
maddios is online now Report Post
Have you tried to lock the car and leave it for 5 mins then unlock the car and see if the steering wheels frees up when starting the car?
yeah, it's been like this since I picked it up on wednesday.
I don't hear anything ticking or moving at all. I already disassembled the dashboard under the steering column and checked for voltages at the motor and there's nothing, 0.0v there.
So either my central body module is toast or something else. Any pointers on where to look would be greatly apreciated.
Can anyone point me to the specific module in INPA which is responsible for controlling the steering wheel (actual driver)?
thanks for the info, I checked the SZM module and there were no faults stored.
At this point i'm wondering if it's a wiring problem or the module is just toast, like a relay/transistor ate it and the module doesn't know about it.
where is the SZM located so I can take a look at it?
PS: I'm trying to use the WDS but this thing is so hard to read compared to the old school wiring diagrams from cars like the e34/e24 that i'm used to.
I had this problem after the SZL was replaced, the whole car has to be programmed after changing the SZL. The steering column motor did not work after programming, it had to be programmed again and then the motor on the steering column worked.
Discussion Starter · #7 ·
So, I think my central console center switch unit is dead. I pulled it out, it's getting power but not activating the steering wheel.
No errors stored in it and the actual steering column buttons are working when I diagnose them in inpa.
If I get another control unit and swap it in, I don't have to code it, right? as long as it has the same functions it should work.
Discussion Starter · #8 · (Edited)
Ah, hm, maybe i should check to make sure it's not a programming issue. Though I doubt mine was ever replaced.
Discussion Starter · #9 ·
I googled around but I'm not sure what I'm looking for, anyone have a guide for "programming" the module to make sure it knows it's supposed to control a steering wheel?
Discussion Starter · #10 ·
So I got a replacement center console button unit. It's exactly the same as mine, still no dice.
So either this one has the same exact problem (got it used) or it is indeed a coding issue.
I'm going to look at the coding this weekend maybe and try to figure out what's the deal. Any coding advice is welcome as I've never tried to do this before, I've just messed with stuff like rolling up windows with remote.
I'm going to do a bunch of research on the bmwcoding forum right now.
Discussion Starter · #11 ·
So, PRM5 was right on, in my case it was a programming issue. I recoded the SZL with defaults and my steering wheel works now :biggrinbounce:
Really wonder what the hell previous owner or their shop did to screw this up.
Glad you got it figured out :cheers:
Discussion Starter · #13 ·
that being said, I now have a spare SZM :) anyone need one?
It's the one with heated seat, pdc and tpm buttons.
So, I have the same issue now on my ‘new’ 2006 M5. With ISTA-D now talking to the car, I can see that the steering column module (SZL) can read the switches and I can make the motors move using ISTA to manually command the center switch module (SZM?). Neither module is throwing an error, and if it matters, I have the Mac-Daddy center module (heated, cooled seats with bolster width adjustment).
I suspect something with the Hall effect sensors is wonky, as the are large negative numbers in the SZM.
Is this something that is fixable by reflashing the SZM, or do I need to replace either the motor assembly or the center module? I‘ve had the car for about 11 days and am a BMW noob, so any help is appreciated.
thx.
-sqbadyvr
thx.
-sqbadyvr
Ok, reflashed the module and got nada, so next step is the motor.
Did you flash with winkfp?, if yes. did you code the module after the flash? flashing/programming and coding are 2 different things.
To code a module you need to use NCSExpert software.
Post the values you see in ISTA.
Yes. I didn’t code module, though. Right now, I have battery disconnected as I work on engine, but when I finish that (once parts arrive!) I’ll post those. Thx, @platii
I know its been 2 months but i'm in the same boat as you and was hoping you managed to figure it out and get it sorted? I bought a master licence for Protools and tried to use it to default code the new SZL module i have and give it the same VIN but have been unsuccessful getting the desired result...
1 - 20 of 28 Posts
