Got another question. Has anyone switched out their old speakers with the ones from bsw and did it improve the sound?
Yes, and YES. I was less than impressed with the M-audio system and have a good deal of experience installing custom systems in my past cars (anything from a Gallant to a 350Z) and decided an upgrade was in order. I've done complete overhauls with multiple amps, components, subs, new wiring, etc but didn't feel like going to those lengths with the M. Even with those complete overhauls I kept stock grills, hid the amps, no silly stickers, very much stealth installs. I want good sound quality, not to impress the 17 year old down the street with dual 12"s and a hearing problem.
The BSW system cleans up the mids and especially the highs a great deal, much improved imaging and clarity. It does emphasize how utterly craptacular the M audio subs are though, I'm still seriously considering BSW's subwoofer option. Yes, BSW does cost more than individual components, but it is pretty much drop in, very stealthy and mostly a straightforward install. You keep the factory door enclosures, wiring, and locations....
BSW will tell you that the Stage One kit is not for M-audio cars anymore, this is technically true as they don't give you a couple of brackets for the coaxial rear tweeters. (M audio has a mid woofers AND tweeters in the read deck, base audio has only mid woofers in the rear deck and tweeters in the rear doors) You can use the OEM M-audio brackets though, check out my DIY notes on installing BSW I in a M-audio car below. These are annotations on the instructions BSW provides:
http://www.m5board.com/vbulletin/e3...167319-bsw-stage-1-m-audio-install-notes.html
I'm happy with the BSW solution, I know I could get even better sound quality from a custom install with better amps, dynamatting, etc but if I assign ANY value whatsoever to my time it doesn't work out cost-wise. There is NO WAY I'd let Best Buy or most of the custom sound shops get their hands on the M, to many horror stories. I'd rather spend my time replacing hoses, CPS sensors, fuel level senders, etc.... :grinyes:
