1 - 6 of 6 Posts
I have a couple of questions:
1) Is the Tire pressure system an active one (showig pressure of all tires at any time) or a passive one as in the E39 M5?
2) Is there an option for active seats or ventilated seats?
No.2 is discussed extensively in one of the very recent threads. Have a read there:-
http://www.m5board.com/vbulletin/showthread.php?t=45480
About no.1. The M6 press release reads "Providing both visual and acoustic signal, the Tire Pressure Indicator warns the driver of a sudden or gradual drop in the pressure in one of the tires".
So I suppose it is an active monitoring system.
my guess is that it is in INDIRECT tire pressure monitoring system as to my understanding, a DIRECT system would require a sensor inside the tire replacing the valve stem.
Use of the M-Mobility tire repair system would then render the sensor useless and require expensive replacement.
Government legislation of DIRECT monitoring systems does not come into effect for a few years I believe. It will be interesting to see how manufacturers come up with DIRECT systems that won't be a pain for customers.
That is not correct. The SL 55 has a direct tire monitoring system along with a tire repair kit instead of a spare tire, a la M-mobility kit.
From your quote, it sounds like it is an indirect system. The system only signals (audio and visual) when pressure drops
If you're reading literally the key thing is "one" of the tires- the indirect system goes by relative rolling radius- if they all change at the same time the system cannot signal a fault. FYI on my 02 7 there was an active/direct TPM system- it really gave fairly accurate tire pressure of each tire. The system used a different valve stem on the wheels. Thats what to look for when you see a car at a show. If it looks thicker and perhaps like an octagon from the outside then thats the system from the 7. The 05 7 I have does not have this system though......
1 - 6 of 6 Posts
