REPOST: TerraClean test description and review --- Really long
I cut and pasted from MS Word, and ended up with a lot smileys. I should have previewed the post first.... Sorry.....
Hi,
<o>
> </o>
First of all, here is a quick background on history of my car. It’s a February 2000 built car with the original ring design. I bought the car from an independent dealer about 2.5 years ago, with 68kms, as my everyday ride. The car was off a 3 year lease. Based on an inspection by my mechanic the car was not in the best shape. However, this was a complex deal, involving my ’88 Lotus Espirit trade-in, aftermarket warranty as well as couple other things. After due consideration, I have decided to go ahead anyway.
<o>
> </o>
In all of my previous cars, I have been using Redline 20W50 synthetic oil, and I had started the M5 with it as well. Suffice to say, the independent shop had no clue about the old ring design and the requirement for 10W60 oil. I had been using the synthetic oil for about year, before I came across couple threads related to the old ring design. I have switched to 10W60, and I have been religious about using it since. The car has an oil change every 5,000 kms. On the average, it burns about 1 quart of oil every 2,000 kms.
I have about 120,000kms right now.
<o>
> </o>
About a year ago, my check engine light started to come on after few cold starts. After few days, it would go away, and then come back few days later. I took the car to the dealer, they reset the codes couple times. Again, nobody was aware of the carbon build up problem. I ended up buying a peake code reader so that I did not have to waste my time with the dealer. Anyway, I had the dreaded “Secondary Air Too Low” code. After couple months, the check engine light was on all the time. Whenever I would reset the code, the light would come back after 3-4 cold starts, and stay on.
<o>
> </o>
Since I am planning to keep the car for few more years, I was not too “freaked out” about this problem as it does not affect the car performance overall. However, the check engine light is very annoying, especially at night. My current solution is two pieces of black electrical tape over the check engine light.
<o>
> </o>
I have attempted to “fix” the problem by cleaning the secondary air tube, replacing the shutoff valve as well as injecting cleaner through a hole in the pipe. I have not been successful at all. The check engine light came back on within 3 cold starts.
<o>
> </o>
This summer, I have decided to perform a bit of “clean up”. I have changed all oxygen sensors, all cam position sensors and MAF’s (thank you David). The car ran much better, but I still had a “dead spot” between 2,500-3,000 rpm when accelerating, especially in the second gear. I thought that a fuel system clean up would be a good thing as well as looking at removing some carbon from the combustion chambers. I was in the process of doing some research on BG Products (
http://www.bgprod.com/products/fuelair.html) , since there is a shop close to my house which performs this service, when the Terra Clean topic was started.
<o>
> </o>
OK…. Enough of the preamble….
<o>
> </o>
After Stephen offered to perform the carbon removal service on my car, I have decided to go take a look at the place first. After contacting Stephen, we have arranged for a tour of the facility. Terra Clean is part of a larger company which produces different types of automotive diagnostic and remedial products at their facility in <st1:city w:st="on">Mississauga</st1:city>, suburb of <st1:city w:st="on"><st1>
lace w:st="on">Toronto</st1>
lace></st1:city>. I was surprised that they actually do R&D and manufacturing in <st1:country-region w:st="on"><st1>
lace w:st="on">Canada</st1>
lace></st1:country-region>, rather then just importing from off shore. I was told that the overall company does about 28 million a year in revenue. After the tour, we have agreed that I would bring the car for the carbon service the following week.
<o>
> </o>
Next week, I was greeted by Stephen and one of the owners of the parent company. It turned out that the owner was going to perform the carbon service himself. After a short discussion, we have agreed on the following protocol:
<o>
> </o>
- Perform a borescope inspection of two combustion chambers.
- Perform the carbon removal service.
- Perform another borescope inspection of the same two cylinders.
- I would drive the car for a week or some.
- Perform third borescope inspection.
- We would add fuel additive for additional fuel system and carbon cleaning.
- Perform final borescope inspection
<o>
> </o>
At this time, we have completed steps 1-6. I have not gone back for the final borescope inspection as yet, due to lack of time over the last couple weeks.
<o>
> </o>
Since I have no practical experience with engines, ( I am a computer geek), I will describe the procedure, what I have seen on the borescope and my driving impressions. I have asked Stephen to prepare videos/images of the borescope inspections as well as a technical write up.
<o>
> </o>
Step 1.
<o>
> </o>
First of all, two spark plugs, closest to the front of the engine on the left side were removed. Borescope was used to look at the top of the pistons as well as cylinder walls. They had a bit of hard time trying to get a look at the valves. Based on my uneducated assessment, the combustion chamber was a mess. There appeared to be a very substantial built up of carbon on top of both pistons. In addition, there seem to be carbon “flakes” floating in the cylinders. You can see them in the video “propped up” against cylinder walls. I was surprised to see these “flakes”, since I had assumed that the combustion process would break them up.
<o>
> </o>
Step 2
<o>
> </o>
First of all, I used my peake reader to rest the engine codes. Next step was to pull fuel pump fuse. TerraClean injection device was attached to the fuel line in the front of the car. In addition, they have inserted another fuel pressure gauge, in order to verify accuracy of the fuel pressure gauge in the TerraClean unit. The TerraClean process involves running two different cleaning agents through the engine one after another. Two cans were attached to the TerraClean unit. I was told that each can should take about 10 minutes of engine run time. It turned out that the first can was finished after only 5 minutes on my car. Stephen suspected that this is due to the fact that S62 engine take much more fuel, then a typical engine. We have decided to use two cans of the first agent, rather then just one. The whole process was finished in about 20 minutes. After disconnecting the TerraClean equipment, re-enabling the fuel pump, the car started without any problems. However, my check engine light was on. I have used the peake reader again to read the codes. The reader reported about 8 engine codes, all related to Air Fuel mixture. I had reset the codes, and everything was back to normal.
<o>
> </o>
Step 3.
<o>
> </o>
The same plugs were removed again, and another borescope inspection was performed. Based on my amateur opinion, it appeared that a good portion of the build up on the top of pistons was gone, especially in areas close to the cylinder walls. The remaining carbon on the top of the pistons looked as if it was “wet”. Finally, the “carbon flakes” were gone. These are my visual perceptions. I hope that our “in-house” experts will be able to provide much more insightful comments, once Stephen posts videos.
<o>
> </o>
Step 4.
<o>
> </o>
I drove the car for about 10 days following the TerraClean procedure. My impressions were that the engine was running more smoothly and for lack of better word, more “snappy”. Also, the “dead spot” around 2,500 rpm in the second gear disappeared. Stephen indicated to me that I should notice a better mileage as well. I reset one of my mileage counters, but after 10 days I could not see any substantiated mileage improvement. I was averaging about 15 liters/100 kms.
<o>
> </o>
Step 5
<o>
> </o>
I dropped off my car at their facility in the morning, since I had couple meetings that day, and I could not stick around. I went back in the afternoon to pick up the car. I have not seen the results of the third borescope inspection personally. Stephen and the owner did mention to me that they thought that there was additional reduction in the carbon build up. Again, I will refer this question to our experts, once the videos are available.
<o>
> </o>
Step 6
<o>
> </o>
As the last step that day, Stephen put in a fuel additive in my full fuel tank. He indicated to me that the additives will provide additional carbon cleaning as well. I have used up about 3 tanks worth of gas since the last borescope inspection.
<o>
> </o>
Step 7
<o>
> </o>
I am planning on scheduling the final borescope inspection with Stephen sometimes over the next two weeks.
<o>
> </o>
The car continues to run smoothly and with a good snap to it.
<o>
> </o>
Here are my overall impressions:
<o>
> </o>
First of all, a disclaimer: Uview performed the procedure free of charge, and addition, I have received another freebie as well ( more on this later ).
<o>
> </o>
- The company which owns Uview and Terraclean is real, and they manufacture everything in house. I was quite impressed that one of the owners worked my car himself.
- The procedure is fairly simple to complete. I would recommend that you ask technician to use two cans of the first cleaning agent, due to our engines’ thirst.
- Keep you peake reader handy after the procedure. Likely, you will have about half a dozen of Air Fuel codes.
- The car feels smoother and stronger following the procedure. I have tried to account for “placebo” effect as best as I could.
- I have not seen a substantial improvement in mileage. However, I might just be driving more aggressively then before the procedure.
- To my uneducated eyes, the procedure did remove substantial amount of carbon from the combustion chambers.
<o>
> </o>
Rather then providing a recommendation, I will just say that I will be getting the TerraClean cleaning done again sometimes in the late spring next year, at my own expense.
<o>
> </o>
If you have questions and/or need a clarification, please, post them, and I will try to reply to them as soon as I can.
<o>
> </o>
Meantime, I hope that Stephen posts the videos soon with an educated analysis of the results.
<o>
> </o>
One more interesting observation regarding my carbon build up problem….
<o>
> </o>
Over the last two weeks, the weather turned much colder in <st1:city w:st="on"><st1>
lace></st1:city>. About five days ago, my check engine light went off by itself. My jaw just about dropped to the floor. I thought a “miracle”, either weather or TerraClean fixed my carbon build up problem. Unfortunately, this morning my trusted “Seondary Air Too Low” light is back on. However, this “on/off” cycle has not happened in last eight months. Please, form your opinions whether there is any significance to this.
<o>
> </o>
Second interested related story…
<o>
> </o>
While talking with Stephen and the owner during my second visit, they told me that the company also makes a product for killing odour in car air conditioning systems. My wife drives 2005 E55 AMG, and since the beginning whenever she would turn the car on with A/C on (almost always), there was always a really bad odour for first few seconds from the vents. Stephen offered to perform the odour killing service on my wife’s AMG free off charge. Monica brought her car in during our visit for Step 5. The odour cleaning procedure took about 30 minutes to complete. My wife is thrilled. As of now, the Mercedes is odour free…
<o>
> </o>
I hope that M5 forum members will use this write up, together with videos (to be posted by Stephen) helpful in forming there own opinion on the TerraClean product.
<o>
> </o>
I would like to thank Stephen for his hospitality.
<o>
> </o>
<o>
> </o>
Andrew
