1 - 14 of 14 Posts
I bought the car two years back, owned by an older gentleman. He had taken good care of the car but still, I got the pre-purchase inspection followed by addressing some maintenance items before bringing it home. Garage kept and even in the garage, I keep it under Noah cover. Besides a short shifter and muffler delete, it is completely stock with Euro Hella headlights. No dings and dents on the body, the interior is extremely clean with a few imperfections. Pillar-A trim/cover is a little de-shaped, driver & passenger side door trim has a crack, and the center console trim is wrapped. Foldable rear seats with fully functional front seats, 2 original keys, and the original window sticker.
I am the fifth owner and have owned it since 8/2017. 3rd and 4th owners were in the Navy and knew each other. Due to unforeseen circumstances, I have to sadly offer it up for sale and will be happy to answer your questions. I have a thick folder of its maintenance record with a few oil-change records missing. Other than that everything is there since purchase. I have tons of pictures in Dropbox, attaching the URL.
Asking Price: $29K
VIN: WBSDE93402CF90235
Below is the maintenance items' list in descending order:
DateService Item DescriptionMileage
6/18/2018Valve Cover Gaskets (Both)
Air Filters
Micro Filters
82600
10/27/2017Power Steering return pipe, suction hose, pressure hose, seals
Steering fluid flush
82450
9/15/2017Oil Change82400
8/26/2017Rear Brake Pads and Rotors
Shaft Seal
Differential Seal
Differential Fluid
82108
7/18/2017Brake Fluid Flush81857
3/23/2017Driver Side Front Airbag - Service Action81452
3/16/20162 Front Tires Michelin 79875
2/18/2013Brakes and Rotors
Fuel Filter
Oil Change
71,731
1/21/2013Front Thrust Arm Bushing Kit
Brake Fluid
Anti-Freeze
71,465
6/11/2012Steering Fluid Flush70428
4/9/2012Differential Seal
Differential Fluid
Gear Box oil
Washer pump
Valve Cover Gasket (Right)
70,150
4/5/2012Spark Plugs
Thermostat
Oil Seperator Hoses
Thermostat to Water Pipe O-Ring set
Thermostat to Engile Oil Cooler O-Ring
Air Filter
Fuel Filter
69,888
1/13/2012Pinion Seal68900
12/30/2011Oil Change68900
11/2/2010Oil Change62535
12/21/2009Oil Change57380
11/21/2008Oil Change51028
3/20/2008Oil Change
New Battery
44938
1/23/2007Rear Tires Michelin 38061
8/9/2006DMTL Tank Pump Replaced35142
7/3/2006A/C Resistor Replaced
Coolant Flush
Drive Belts Replaced
Oil Change
Front Sway Bar Link Brackets Replaced
34409
11/11/2004Air Fliter
Micro Filter
22300
8/2/2004Instrument Cluster Replaced
Mirror switch assembly replaced
Airflow Sensor Replaced
Oil Change
Brake Fluid Flush
21344
4/14/2004Front Tires Michelin19025
6/6/2003Fuel Level Sensor11337
5/2/2003Oil Change
Micro Filter
10859
12/5/20011200 Miles Service
  • Gearbox oil
  • Differential Oil
  • Seal Ring
1286
11/14/2001K40 Radar Detector Installed-
931419
931420
931421
Where in VA are you located?
Still for sale? Contact info sent in a PM.
Alex
Car is sold :)
@stubborn. It was a pleasure working with you! Thank you for an effortless buying experience.
1 - 14 of 14 Posts
