Okey thanks. How can I check if that's the problem?
Here are the codes I got using BMWhat on my android phone:
"ABS/DSC/Brake: ECU not present/no response from ECU" this is strange...
<TABLE style="WIDTH: 741.8pt; BORDER-COLLAPSE: collapse" class=ecxMsoNormalTable border=0 cellSpacing=0 cellPadding=0 width=989><TBODY><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap>Motor Control:
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> Engine / Motor
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> Fehler: :About PT-CAN / Message (steering angle) / Message Error PT CAN / Angle of the steering wheel / steering wheel angle
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> Code: CDA1
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> Fehler: :Message (maximum demand DSC) / Message Error PT CAN
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> Code: CD98
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> Fehler: :Message (status DSC) / Message Error PT CAN
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> Code: CDA5
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> Fehler: :Message Error PT CAN / Message (wheel speeds)
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> Code: CDBB
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> Fehler: :Message (speed, 1A0) / Message failure / Message (vehicle speed)
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> Code: CD9C
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> Fehler: :Air Compressor Control Control / AC compressor controller / Air Compressor Control Relay / unknown fault code
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> Code: 27C2
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> Fehler: :EV3 control / Activation EV3 / Tank level / Lambda adaptation to Vcat stop bank 2 / Control injection valve
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> Code: 27AB
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> Fehler: :Electric fan motor activation / Motorluefter control / Power management battery quiescent current of injury / e-fan
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> Code: 279D
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> Fehler: :Intake manifold pressure / Relative time validity / Time relative plausibility / Nitrogen oxide sensor lambda probe signal
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> Code: 2AFD
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> Fehler: :SMG-monitor module / Rough running measurement / SMG-module monitoring
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> Code: 2B10
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> Fehler: :check at lower top / Mass air flow sensor / Security concept manager action
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> Code: 2B57
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> Fehler: :EV6 control / Activation EV6 / Tank ventilation system / Control injection valve / Lambda adaptation to Vcat stop bank 1
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> Code: 27AA
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap>ABS / DSC / Brake:
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> Active Roll Stabilization / Rollstabilisierung
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> ECU not present/no response from ECU
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> Dynamische Stabilitaets Kontrolle / DSC
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> Fehler: unknown failure CAN / Coil outlet (dump) shorted left front / DSC ECU intern / Internal Error / Internal ECU operating error DSC / DSC-internal
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> Code: 5E18
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> Fehler: Electrical system voltage <9 Volt / Internal ECU operating error DSC / Invalid CAS interface
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> Code: 5DF4
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap>Airbag:
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> Advanced Crash and Safety Management (ACSM)
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> Fehler: Central control timeout / Watchdog reset uP
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> Code: 93A8
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> Fehler: Passenger seat mat / Timeout / Pre-drive check 3: too few messages
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> Code: 93C2
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> Fehler: B + line / Recognized under tension clamp30
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> Code: 93FC
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> Satellite front left door / Tuer vorne links
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> ECU OK, no Fault Code
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> Satellite front right door / Tuer vorne rechts
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> Satellite B-pillar left / B-Saeule links
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> Satellite B-pillar right / B-Saeule rechts
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> Satellite center / Mitte
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap>Transmission Control:
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> Transmission / Getriebe GS 19
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> Fehler: :K-Can Bus off / wheel pressure
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> Code: CF13
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> Fehler: :K-Can Bus off / speed
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> Code: CF16
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> Fehler: :wheel speed
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> Code: CF1A
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> Fehler: :status DSC
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> Code: CF1D
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> Fehler: :steering wheel angle
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> Code: CF19
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> Fehler: :Radtoleranzabgleich
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> Code: CF1B
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> Fehler: :Evaluation steering angle
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> Code: 520A
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> Transmission / Getriebesteuerung
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap>Instrument cluster:
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> Instrument cluster / Kombiinstrument
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> Fehler: supply voltage failure
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> Code: 931D
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> Fehler: CAN signal fault immobilizer
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> Code: A3AC
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> Fehler: Debug Info Combi
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> Code: A557
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> Central info display / Zentrales Display
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> Head-Up Display
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> Fehler: CAN Message failure
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> Code: A4F5
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap>Light/Rain Control:
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> Light / Licht
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> Rain/light sensor / Regen-Lichtsensor RLS
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> Fehler: sorry, unknown fault
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> Code: DA44
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> Fehler: Brake light switch faulty
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> Code: 9CAC
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> Fehler: Battery cut-off relay
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> Code: 9CC3
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> High-beam / Fernlichtassistent
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap>Heating / AC:
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> Air conditioning / Klimaanlage
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> Fehler: Speed K-CAN / CAN message accelerate / K-Can failure
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> Code: E71C
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> Additional heater / Zusatzheizung
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap>Immobilizer System:
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> CAS
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> Fehler: brake light
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> Code: A0B0
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap>Park distance control:
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> Park Distance Control / PDC
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap>Cruise Control:
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> Active cruise control / Aktive Geschwindigkeitsregelung
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap>Sunroof / Roof:
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> Roof / Verdeck
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> Sunroof / Schiebedach
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap>Audio/Navi/Communication:
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> Multimedia-Changer / Wechsler
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> Speech recognition / Spracherkennungs-system
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> Phone / Telefon
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> Hifi Amplifier / Verstaerker
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> Tuner Antenna / Antenne
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> Hybrid Radio USA
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> Digital Satellite-Tuner USA
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> Headphones / Kopfhoerer Schnittstelle
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> Navigation
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> CD-Changer / Wechsler
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> Audio-System
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> Video
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> DAB
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap>Seats:
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> Backrest width / Lehnenbreiteverstellung
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> Seats / Sitze
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap>Systems:
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> Gateway
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> Steering column switch / Lenkstockschalter
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> Fuel pump / Kraftstoffpumpe
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> Tire pressure control / Reifendruck Kontrolle
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> Passive Go System
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> Power Module
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> Night Vision
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> Flexible Bus-Interface / Schnittstelle
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> Car Communication Computer CCC
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> MASK
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> Center-Konsole
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> Night Vision Camera
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap>Anti-theft alarm system:
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> Interior protection / Innenraumschutz
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> Fehler: Errors in the internal battery
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> Code: 9D12
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> Theft alarm / Diebstahl Warnanlage
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap>Chassis:
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> Air suspension / Luftfederung
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> Electronic damper / Elektronische Daempfer
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> Fehler: unkown failure
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> Code: 5FF0
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> Fehler: timeout CAN failure
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> Code: 5FF7
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> Code: 5FF8
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> Central Control / Zentrale Bedieneinheit
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap>Body:
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> Automatisches Front Steering
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> Trailer / Anhaenger
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> Car Body Module
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> Fehler: RD failure
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> Code: A435
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> Fehler: KBM under voltage
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> Code: A409
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> Fehler: AL pin error
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> Code: A441
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> Tailgate / Hecktuer
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap>Other:
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> ECU A1
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> ECU A2
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> Code: 991D
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> Code: 98DF
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> Code: 98E2
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> Code: 9911
</TD></TR><TR style="HEIGHT: 15pt"><TD style="PADDING-BOTTOM: 0cm; PADDING-LEFT: 3.5pt; WIDTH: 741.8pt; PADDING-RIGHT: 3.5pt; HEIGHT: 15pt; PADDING-TOP: 0cm" vAlign=bottom width=989 noWrap> Code: 9915
</TD></TR></TBODY></TABLE>
Regards
