1 - 5 of 5 Posts
My 2000 M5 has had a soft brake pedal since I got it. I have had the dealer pressure bleed the system, same feel. I had a 635CSi with the same feel. Does not inspire confidence. Are they all this way or do you have a firm, hard pedal? Any tips on bleeding the system?
Tom Lesko
My M5's pedals don't feel like my Indycar, F40 or 348...but it is firm and has good feel to it.
I have a vacuum bleeder that I got from Griot's Garage that works great. You might try that.
Tom,
Ask your dealer to bleed the brake system with one person pumping the brake pedal and using the DIS tester to run the DSC/ABS unit, and it´s feeder pump.
The TIS repair instructions for brakes 34 00 048 and 34 00 050 describe the procedures. Have them perform both to the letter.
"Normal" brake bleeding doesn´t get air trapped in those parts out, since the electrically controlled valves are shut.
I had this done on my car, and it did produce a bit of air.
Best Regs,
David
Tom Lesko
Dave Z. commented on all this here:
http://www.m5board.com/vbulletin/showthread.php?t=52187
1 - 5 of 5 Posts
