1 - 19 of 19 Posts
'22 X5 M50i, '12 E92 M3, '08 E60 M5
in typical diy fashion, a preventative maintenance job on a fully working car turned into broken coils and a not working car.
Drinkware Sleeve Font Gas Barware
Hood Motor vehicle Automotive design Vehicle Car
What gives me some comfort the #10 that was broken was already broken when i got to it, it was missing one of the ears that the latch hinges on, so it was a no go. The number 4 one was pretty surprising, since it just ripped clean off, and I left #5 in there because I saw the connector was already cracked.
I've been using a 3/8" extension fed through the opening in the clip to pull them out. Is that not right?
.. And more importantly, now what? How do I get the remnants out? I thought about drilling a hole and getting a long screw in there, but not sure that's such a good idea.
Take long needle nose pliers, push the two pointy noses on either side, get a good grip, and very slowly, keep trying to turn counter clockwise. You are NOT trying to pull the coil out, but without slipping, turning the coil counter clockwise. Keep turning, with patience, the coil will turn slowly and pop out.
The coils are designed to go in clockwise and come out counterclockwise. I accidentally discovered this. Attempting to pull them out vertically leads to bruised fingers and broken ego, ahem, coil.
I cracked off the tops on two of mine. I ended up carefully screwing a wood screw into tops and used that to pull them out. Took longer to get those two off and clear the plastic crumbles without letting them get into the combustion chamber than it did to do the rod bearings haha!
Oh man, that actually makes me feel good that I’m not the only one, and that you guys got it the way I was thinking of going. Still sucks but at least it’s not (all) my fault.
Lmao, IT IS ALL YOUR FAULT. YOU are not doing it using the right methods and tools.
(and our faults too, none of us have done it correctly)
Discussion Starter · #11 ·
I twisted mine before pulling them out, but the two near the firewall broke when I tried to twist them. I'm thinking those two get lots of heat during that 35K mile interval.
Yeah same. Both coils by the firewall had cracked ear tabs and twisting doesn’t seem to have helped anything. So. Much. Fun.
Discussion Starter · #13 ·
Not having much luck.. thinking about just pulling the valve covers and spark plug tubes. Is there a diy for that somewhere? Ive done it on an S54 before it’s not a huge deal. Just more trouble than I was signing up for.
Administrator
Hate to sound like a broken record but you need to first break the rubber boot to spark plug seal. Can you try to rotate whatever is left of the coil? Once that seal breaks pulling it out shouldn't be too bad. If not then cover off it is. No DIY that I know of but do you have newtis access?
Discussion Starter · #15 ·
No, please do — I’m new to the s85 (obviously ) and you’re being very helpful. I’m gonna try again today but I’ve done at least a 360 on them without much luck.
Isn’t newtis shut down because of bmw ag? I have ista so I can just look up the procedure there. Was just looking to avoid another “it’s not in the manual, but you need to do this first” situation.
Discussion Starter · #17 ·
Gotcha - yeah no tips on removing the valve cover other than see what ista/newtis instructions show.
Are there any "while you're in there" tasks that I should tack on if I go this route? The S54 had valve shims you had to do (I know that's not needed here). If I end up pulling the covers, my plan right now is to replace the VCG, the plug tube gaskets, the oil filler tube gasket (mine seems to be leaking), but then that's it.. I'm not really seeing anything else to do there..
Discussion Starter · #19 ·
oh man. two down, one to go. so you were right @flacoramos -- it wasn't fully releasing the plug. i'd rotate about 180* and it would spring back. I'm down to the #10 coil but it's fighting back.
taking a break now, tomorrow i'll need to try disconnecting the fuel tank breather pipe as it's blocking access to the #10 coil...
1 - 19 of 19 Posts
