1 - 14 of 14 Posts
Hi I am new to the forum.
I am planning to install snow tire on my M5. It has original 19" on it.
I was wonder could I run 255/40/19 all around?
In terms of actual performance in the snow you need 18 inch tires...check out this from tirerack.com
A Minus Size Tire and Wheel
Minus Sizing is simply traditional Plus Sizing techniques used backwards. For example, a 2003 Volkswagen Jetta GLX VR6 would store its original 205/55R16 (or optional 225/45HR17) tires in favor of Minus One or Minus Two size 195/65R15 tires on 15" wheels.
In both of these examples, not only would snow traction be enhanced, but the cost of a Base Model or Minus Size winter tire & wheel package is usually lower than a package maintaining your vehicle's original size tires and wheels.
So for us M guys - you go with 255/45-18 all around.
Good luck
Good luck
Do you know 255/45/19 will fit on the stock rear rim?
ran 18's for a couple of years - didn't like the look
now use 255/40 19 on the factory wheels for the last 2
work great - no discernable difference in snow performance from 18's
hmm -sorry to sound like a total moron, just looked at the car- I was correct first time- 255/40-19 Michelin's which I believe I got from tire rack.
Over the years I have had multiple cars driven all year round in snow highway/city and as long as you buy a good brand (which at this size is really all there is) they are all the same.
The M5 is great in the snow.
I do have the 18's in my shed with dunlop snows (about 10000kms) on repro M5 alloys if you are interested , but the 19's do look quite a bit better.
Good luck
BT
while tirerack is correct...I run 255/40/19 and this is my 3rd winter on Blizzak LM-22...i have 8 mm of tread left...no problems driving in last weeks 12" snow dump....
so for the majority of us...19's will work just fine
I may have to upgrade to 19s...as many have said - the 18s sure make the car look...well...plain. UGH!
Anyone have experience with the blizzak lm 22?
By the way this will be the first winter I'll be driving this car.
Any Tips?
I run OEM M6 staggered wheels with Blizzack LM-22 in size 255/40-19 all around based on a recommendation from Tire Rack. They work great, both for cold weather (below 40 degrees F) grip and traction in snow. No complaints at all.
1 - 14 of 14 Posts
