Does anyone take their beast to the snow?
With snow tires the M5 runs just fine in the snow, as long as it's not too deep. I run OEM M6 staggered wheels with non-staggered tires. The tires are Bridgestone Blizzack LM-22 with size 255/40-19 all around based on a recommendation from Luke at tire rack (check out his annual winter tire post). He recommended the smaller front size for the rears for better snow performance with the added benefit of being able to rotate front to rear to prolong the life of the set.Is the car actually controllable on snow tires? What is the exact size of the tire you are getting for the front and rear? Thanks
This is bad advice....I live in an area called "the snow belt" that averages over 100" of snow...https://kb.osu.edu/dspace/handle/1811/23329 and you will go absolutely nowhere on summer tires...Im gonna stick with satandard rubber in the snow. Ive never had an issue in the snow, in any vehicle. Im a snow and ice driving instructor so if you need any advice let me know.
+1This is bad advice....I live in an area called "the snow belt" that averages over 100" of snow...https://kb.osu.edu/dspace/handle/1811/23329 and you will go absolutely nowhere on summer tires...
In 100" of snow i'd expect nobody to be going anywhere in anything other than a Skidoo, BV206 or similar 'oversnow' vehicle (or maybe ski's or snowshoes). Thats over 9 feet of snow, about as tall as a bus. Are you sure your not tunneling under the snow? lol. Driving on ice or snow is all about knowing how ice and snow works / reacts and how your car can affect it. Once you have grasped that its easy (ish). lol True, not all cars are suited to snow or ice conditions but that doesnt mean they cant be used.This is bad advice....I live in an area called "the snow belt" that averages over 100" of snow...https://kb.osu.edu/dspace/handle/1811/23329 and you will go absolutely nowhere on summer tires...
last year in the UK you had what some people in the US would consider a mild snowstorm, and the whole country stopped functioning for days on, did you drive the M5 with summer tires in those days ? and how far from you garage door did you go ? 1 meter, 2 meters ? ........2.5 meter ?In 100" of snow i'd expect nobody to be going anywhere in anything other than a Skidoo, BV206 or similar 'oversnow' vehicle (or maybe ski's or snowshoes). Thats over 9 feet of snow, about as tall as a bus. Are you sure your not tunneling under the snow? lol. Driving on ice or snow is all about knowing how ice and snow works / reacts and how your car can affect it. Once you have grasped that its easy (ish). lol True, not all cars are suited to snow or ice conditions but that doesnt mean they cant be used.
Here in Britain we dont really get much snow so to speak. What we get is actually worse. We get snow (normally a wet and warm flake), then freezing rain, then a deep freeze. The result is a lovely thick balnket of sheet ice with a crust of frozen snow on top. Then the gritters come along and either turn it into slush (which is ok but filled with salt and stones), or plough off the top layer to reveal a fine sheet of slick black ice. No car, no matter what the tyres its running (unless studded) is good in these conditions. As i said above, learning how the ice, snow or crust can work for you is the best way to being able to drive safely in these conditions. Simple skills is all it needs.
Eddie
Thanks but, I don't need reminders about the code of conduct in this site. I was not trying to be funny, just stating the obvious facts. Fact is you have not driven the M5 with summers in the snow, although you had good experiences with the RS6, so you assume it is the same.Lets not make this a cock swinging match about who had the biggest snow storm. I too have seen real snow. Ive spent many months working and living (sometimes only just surviving) in the arctic circle. Ive operated in temperatures of -62c, suffered weeks of constant white-out, driven across glaciers, through snow drifts and over frozen lakes and rivers. Ive also driven standard cars in the same conditions with a near perfect success rate.
Asking me how far i got out of my garage is neither funny, clever nor welcome. This is a site for constructive commenting / criticism, not belittling people you have never met and know nothing about. I'd challenge you to take your experience of dry snow over here to the **** we have to deal with. Youd need a whole new set of rules and i'd imagine youd be stuck faster than you can say, 'ah crap!'. Im not saying your environment is easy to operate in, its just different. I just dont like people telling everyone they need to spend hundreds of dollars / pounds on snow tyres they probably wouldnt need if they knew how to drive correctly in the conditions.
My last car was a 510bhp / 550lbft Audi RS6. Granted it was a Quattro, but it still had summer tyres on with 275/30/19 profile. Thats a lot of torque to put through any car (Quattro is rear drive biased too). I never had a single problem with the snow we had last year, or any year for that matter. I drove from the south coast of England right up to the North of Scotland in appalling conditions without a single issue and felt very safe in doing so. There were cars abandoned everywhere and the roads were 'so called' closed due to the conditions but as per usual it was down to poor skills by drivers that the closure calls were made.
As i said before, its simple skills that are required.
