2007 E63 M6 with 65,900 miles.
Installed BPM Sport Stage I tune and Euro SMG software. Went out for a ride and after about 20 miles on P400, switched to P500S and wanted to push it a bit.
3rd gear, went WOT to near redline (raised to 8600 RPM by tune), shifted and... Transmission malfunction & red cog of death icon.
Took it easy (pretty much coasted) for the next few miles, exited the highway (error had cleared on its own by then). About 7 miles later on surface roads, another tranny malfunction error with RCoD icon appeared. Car would not shift without applying more throttle than usual and shifted very hard after a few seconds. Stopped and shut car off.
Restarted and error remained. Limped home in clunk-shifting fashion. Shortly before arriving, the tranny error was replaced by reduced power mode, shifting was back to "normal." Pulled in garage and then ran diagnostic with BPM Sport flash utility. No DTCs.
Did some research in here and also texted with BPM Sport tech support for awhile. Decided to revert to stock tune and U.S. (stock) SMG program to see if tranny errors abate. SMG pump does prime/run for 7 seconds when opening car door.
Tranny malfunction & RCoD icon are now persistent every time the car is powered on (engine running or not). Tried moving car slightly in reverse and 1st. Gears will not engage unless more throttle than normal is applied. If too much throttle is applied, car tries to lurch. Shut it down and did more research. Bookmarked several threads with the most useful info (for part numbers, etc.).
Taking it to the local indy shop on Monday. There goes my holiday trip.
Since there are no DTCs, thinking it might be a sensor or the clutch release bearing.
Anyone have advice or thoughts on likeliest root cause?
Not enough posts to PM, so please reply here.
