Im sorry to hear about your troubles. I suggest you find a indy shop to pull your pump and send it off to get rebuilt. Ive gotten quotes around the $500 range for the labor. Total cost for the replacement should be $2500 - $3000.omg i am sooooo glad i just got on here today. Last week my SMG pump went out and the dealer is saying they want to charge 10k for a new clutch/flywheel and a new pump w/updated software. i had my car towed back to my house and its just been sitting in my garage. Before i read this I was thinking about swaping out the SMG and just getting a 6spd manual with a aftermarket clutch (to handle the HP) because i heard it would cost around 5 or6k. but if you find any more info about the rebuild plz let me know! asap
BTW, how did you know your pump went out? Did it completely die on you? or does it have issues switching gears?omg i am sooooo glad i just got on here today. Last week my SMG pump went out and the dealer is saying they want to charge 10k for a new clutch/flywheel and a new pump w/updated software. i had my car towed back to my house and its just been sitting in my garage. Before i read this I was thinking about swaping out the SMG and just getting a 6spd manual with a aftermarket clutch (to handle the HP) because i heard it would cost around 5 or6k. but if you find any more info about the rebuild plz let me know! asap
$10k is stupid expensive - that's probably ~20-25% of the value of your car. It is so aggrivating that BMW charges an arm and a leg for these parts, and the dealer exacerbates the problem with techs that diagnose by replacement (rather than diagnose to replace). It is even more frustrating that your SMG failure is probably fixed by a $10 part.omg i am sooooo glad i just got on here today. Last week my SMG pump went out and the dealer is saying they want to charge 10k for a new clutch/flywheel and a new pump w/updated software.
getbmwparts.comomg i am sooooo glad i just got on here today. Last week my SMG pump went out and the dealer is saying they want to charge 10k for a new clutch/flywheel and a new pump w/updated software. i had my car towed back to my house and its just been sitting in my garage. Before i read this I was thinking about swaping out the SMG and just getting a 6spd manual with a aftermarket clutch (to handle the HP) because i heard it would cost around 5 or6k. but if you find any more info about the rebuild plz let me know! asap
Good info I may need at some time. Thanksgetbmwparts.com
Items Ordered:
Item: Clutch, Hydraulic system, Slave cylinder, Slave cylinder, all models
Price: $62.02
Tax: $0.00
Qty: 1
Total: $62.02
Item: Clutch, Clutch and flywheel, Release fork, Release fork, m5
Price: $11.92
Tax: $0.00
Qty: 1
Total: $11.92
Item: Clutch, Clutch and flywheel, Release bearing, Release bearing, m5
Price: $63.65
Tax: $0.00
Qty: 1
Total: $63.65
Item: Clutch, Clutch and flywheel, Pressure plate, Pressure plate, m5
Price: $701.20
Tax: $0.00
Qty: 1
Total: $701.20
Item: Clutch, Clutch and flywheel, Pilot bearing, Pilot bearing, m5
Price: $18.92
Tax: $0.00
Qty: 1
Total: $18.92
Item: Clutch, Clutch and flywheel, Flywheel, Flywheel, m5
Price: $1,325.56
Tax: $0.00
Qty: 1
Total: $1,325.56
All genuine bmw. Give them a try!:M5thumbs:
Jay
Very good information. Thanks!This is what I replaced including bolts, with part numbers etc (ignore the wheel caps and wheel bolts!):
23017838938* MANUAL CHANGE PER VIN - SLAVE CYLINDER 1 $240.80 $240.80
21511223302* MANUAL CHANGE PER VIN - RELEASE FORK 1 $14.52 $14.52
21212283089* MANUAL CHANGE PER VIN - CLUTCH KIT 1 $701.20 $701.20
11211720310 Clutch, Clutch and flywheel, Pilot bearing, Pilot bearing, m5 1 $18.92 $18.92
21212229955* MANUAL CHANGE PER VIN - FLYWHEEL 1 $1,325.56 $1,325.56
36136783536 Wheels, Covers and trim, Center cap, All others, All others 4 $11.40 $45.60
36136781150 Wheels, Covers and trim, Wheel bolt, Black, Black 20 $3.03 $60.60
23017837428* MANUAL ADD - CLUTCH SENSOR 1 $343.91 $343.91
21511223328* MANUAL ADD - BALL PIN 1 $0.98 $0.98
21517570284* MANUAL ADD - SPRING CLIP 1 $3.82 $3.82
23117564680* MANUAL ADD - GUIDE BUSHING 1 $10.22 $10.22
07119905805* MANUAL ADD - PRESSURE PLATE BOLTS 9 $0.58 $5.22
07119904633* MANUAL ADD - FLYWHEEL BOLTS 5 $0.14 $0.70
Sub Total $2,772.05
Shipping $870.27
Tax $0.00
Total $3,642.32
Cheers
Jay
well im going back to the dealer tomorrow but the guy said it was the the pump and sensor...but this evening i wil give all exact details so i am not guessing...BTW, how did you know your pump went out? Did it completely die on you? or does it have issues switching gears?
It is kind of one of those, while you are in there, because if it goes out you will have to repeat the process again...so most people would just get the slave and clutch sensor, as they are relatively inexpensive compared to the rest of the project.My car has 35k miles and need a new clutch and flywheel. Is it worth for me to get the slave cylinder and clutch position sensor if they are fine or is it worth the safety precaution?
