SMG in M3 and M6
767 3
I have only 500 miles on my M6.Can not go over 6000 RPM yet. Gear changes feel a lot slower and softer than in M3. Is trans. protected during brake in?
1 - 4 of 4 Posts
you are in the break in phase my friend.
In short you are stuck in P400 and the car is limited to 6k rpm's so you don't do any damage before the break in is complete. You should be able to make the shifts quicker via idrive or just push the shift button next to the gear shift.
No reason not to use P500S, as long as throttle and rpm restrictions are met, during the break in period.
I felt the exact same thing when switching from my M3 to my M6...even after the break-in....these cars just drive totally different...
With the M3 at lower RPM there is much more kick, whereas with the M6 the thrust is felt more at higher RPM (>5000). It took me quite a while to get used to this, and even now, I love throwing around the M3 as it is more nimble.
1 - 4 of 4 Posts
