21 - 23 of 23 Posts
Discussion Starter #21 (Edited)
Just did the slave cylinder bleed (called clutch bleed in INPA, I guess) and here is the resulting log file:
================================================== ======================== SMG3 Sequential M transmission E60, E63 V1.000 BMW TI-430 R.GALL ========= ================================================== ================ Test procedure commissioning SMG3 (SMG_60.PRG) 15.03.2020, 21:44 =================== ================================================== ====== Vehicle with the FG number:==================================== ======================================= Diagnostic structure
Bleeding clutch slave cylinder / hydraulic line
Test status: Test program ended
Info status: ventilation ended ============================================== ============================= Read fault memory
Error entry 1: 0x520A: evaluation of steering angle <<<< !!!
Error entry 2: 0x4F66: Adaption programs gearbox not fully executed <<<< !!!
Error entry 3: 0x4F67: Adaption programs coupling not completely executed <<<< !!! ================================================== ========================= learning status
: LENGTH SENSOR IS NOT LEARNED IN <<<< !!!
: Transmission has been taught in
: CLUTCH CHARACTERISTICS ARE NOT LEARNED IN <<<< !!!
: Coupling slip point has been learned ========================================
Discussion Starter #22
and the log file for actuator block bleeding:
================================================== ========================= SMG3 sequential M transmission E60, E63 V1.000 BMW TI-430 R.GALL ======== ================================================== ================= Test procedure commissioning SMG3 (SMG_60.PRG) 15.03.2020, 22:05 ================== ================================================== ======= Vehicle with the FG number: =================================== ======================================== Diagnostic structure
Venting the gear actuator!
Discussion Starter #23
Ok, so a quick update... the issue ended up being the clutch solenoid valve. I replaced it and also replaced the pressure accumulator as well since the spare hydraulic unit I purchased is newer. I'm not sure how to interpret the clutch valve characteristics stored, but perhaps someone else here can:
936824
21 - 23 of 23 Posts
