All,
I've had a red cog o'death error for some time at startup, clutch position deviation. If I run the slave bleed routine all is good for a couple of days, actuator bleed routine does not help. This has gone on for some time (haven't had time to get to it). The car is otherwise fine, slave cylinder is new (MLR rebuild), no issues with the clutch position sensor, clutch arm/throwout bearing/pivot all fresh. I have a spare trans/hydraulics set and am in the process of swapping the lower unit for one I have gone through (clean clutch solenoid/new o-rings) with an MLR pump motor on it as well.
So here's the kicker, after getting the actuator supply pressure banjo off, and moving to the clutch slave cylinder banjo (a MFer to be sure), the clutch slave cylinder banjo was not tight. Not loose, just really really light tight. Fluid level was fine and no leakage. I'm wondering if thermals were moving it around a bit and allowing air in?
Any thoughts from the hive?
Only concern with swapping the lower is if the clutch solenoid is not good, although one of the things I was thinking could be the cause of the problem is a sticking clutch solenoid in the car presently.
