Good question. I also have a delaminating driver's side rear view mirror. I was wondering how the glass could be changed. This weekend, I will take a look and try to take apart the mirror housing.
hudson said:Here's the TIS instructions to remove the mirror glass. Sorry I wish they where clearer.
Joe
Thanks a lot, Joe. Your post and instructions were instrumental in me completing the passenger side mirror replacement in all but 10 mins (could have been less if I weren't overcautious).hudson said:Here's the TIS instructions to remove the mirror glass. Sorry I wish they where clearer.
Joe
cosioboy said:Thanks a lot, Joe. Your post and instructions were instrumental in me completing the passenger side mirror replacement in all but 10 mins (could have been less if I weren't overcautious).
I had a weird delamination with the size of a quarter coin and was driving me crazy, not sure what caused it. Shopped around for the mirror and got the best deal from Cirlce BMW through mail order for $233. Not cheap but considering it is always in your view, it was becoming a real nuisance.
Cheers again :thumbsup:
Gary,grp said:Yes, the instructions were great, I just did the drivers side change. I say "just" ...
It took all of 30 seconds to remove the old and another 30 to connect the new. And then ... 2.5 hours to try and move that blo*dy circular ring into the lock position. And even then, I didn't succeed. Ended up passing the dealer in the morning - they seemed to be just as clueless (and apparently didn't know about or have the special tool). I sat for 45 minutes while watching 4 BMW techs try to work it out. I explained (in my bad French - I'm in Switzerland) that a special tool was required but apparently they thought better... When they realised I was watching their progress, they took the car "out back" to sort it out. After another 20 minutes, the car came out and it was done ... but what a hassle.
In the time I personally tried, I used screwdrivers, tiny allen keys, other "implements" laying around, I then tried to "make" a tool and ended up stabbing myself in the hand ...
Glad you were more successful than meDid you have the special tool?
Gary.
cosioboy said:Gary,
Sorry to hear you had issues with the install. I guess I was lucky (or perhaps the pasenger side mirror has less quirks). Didn't need any special tools though.
At least you can consider yourself lucky for changing the driver's side mirror because it is significantly cheaper than the passenger side (I guess because of the convexity).
hudson said:Gary,
I use a plastic lever that I got from a windshield installer. It works perfectly. I'll try to get a picture for you.
Joe
AliM5 said:ok i want to change mine too, but let me get this straight, $250+ for only one side glass?
Same here...What a PITA!!!!I hate to bump this old thread, but I'm having a very difficult time seeing the "mounts on servodrive". The broken mirror came off easily when I slid the lock to the right but I cannot get the new mirror to clamp onto anything. A rubber gasket surrounds what is a quite round actuator (?). I expected to see some mounts or other protruding bits for the lock to lock onto but I can't see them and can't get it to lock down.
Any ideas? Thanks.
