Short Shift..
1729 22
Now that my M seems to be healthy! After a £180 visit to the dealer, I was thinking of a Short Shift for her. Does anyone have one or any experience with having one fitted or fitting one?
1 - 20 of 23 Posts
Not sure if this helps: http://www.uucmotorwerks.com/
I think if I was going to get one I'd get this one. I think Rob Levinson plays a big part in UCC and has this fitted to his touring, have a look here: http://www.robertlevinson.com/M5_Touring/
Cheers
Brian
I ordered my Evo 3 Short Shift from UUC on Wednesday night. It was despatched yesterday, I hope to receive it soon.
I spoke to Rob on the phone, lovely bloke. He clearly has intimate knowledge of the M5s (I'm sure that's helped by owning one!)
I was also planning to order some of the uprated gearbox mounts, but they were out of stock for the moment unfortunately.
So far, excellent polite service and thanks to the exchange rate, great prices too!!
:wroom:
· Vendor
:) Thanks very much for your kind words.
I've actually got two M5s at the moment. Sometimes I think they follow me home like lost kittens. Very fast and exceptionally good-handling kittens, that is.
Exciting news for M5 owners... the DSSR is now available for the E34 M5 6-speed! Ideally you would fit it with the UUC Evo3 shifter, but it will make a huge improvement for any brand shifter, even the OE piece. For details, please see:
http://www.uucmotorwerks.com/dssr/
AndyE said:
I'll be fitting mine next week, I'll let you know. I get the impression it's a little bit fiddly.
Andy,
let us know how awkward it is to fit the DSSR.
Compared with a standard 6-speed, the UUC short shifter on mine is definitely a big step forward. Less lateral play would be even better!
Sam
Sam Thake said:
Andy,
Sam
Hi Sam
Did you get this fitted or was it on the car when you got it. I need a short shift for mine.
When I had the E30 M3 it did wonders for the car and even though I know it did not provide any more horsepower it made the car feel so much better.
brgds
Simon
Simonal said:
Hi Sam
brgds
Simon
Simon,
It was on the car when I bought it; fitted in 2000 by the PO a few months after the main conversion.
I got straight out of my 540/6 into the M5 and it was like chalk and cheese.
All that's needed now is to tighten up the side-to-side movement.
What I'm not sure about is how much the DSSR will remove and how much is inherent in the transmission internally. Maybe Rob L will give us a view.
Sam
· Vendor
Sam
It's approximately 75% external, 25% internal to the transmission:
Typically, total in-gear lateral free play is 1" - 1.75" measured at the top of the shifter. With the DSSR installed, that should drop to .5" or less.
The remainder is within the transmission and is not feasibly reduced.
Thanks Rob,
Mine is slightly under 1" in the 3rd-4th plane, maybe 1.2" in 5th-6th and getting on for 1.4" in 1st-2nd. Is that typical?
If so, it sounds a worthwhile mod, as long as fitting it isn't too much of a pain!
Sam
· Vendor
Sam Thake said:
Thanks Rob,
Sam
That's typical. Some have more, some less.
Fitting the DSSR is very straightforward.
- Rob
Sam Thake said:
Andy,
Sam
Sam
I didn't buy a DSSR (yet), but the EVO3 short shifter kit. I fitted that tonight.
Fitting the kit was easy enough. Took about two hours including lifting the car up and changing the gearbox mount bushes too.
What I do know now, is that fitting the DSSR would be easy. Just a case of popping the circlips off the existing selector rod, and replacing the rod and pins. Ten minutes of work once you're under the car, maybe?
No doubt the DSSR kit comes with new pins, washers and circlips, so it's an easy job.
Both of these jobs will to be easier if you remove the gearbox mount stay though, it's big and gets in the way. Obviously that's just a few bolts.
This (above) is no exaggeration. Mine has at least that much play, possibly more. I plan to sort this out next.
Oh, and remember not to fall asleep while you're lying under the car. I nearly did. hiha
1 - 20 of 23 Posts
