1 - 4 of 4 Posts
I don't have the BMW one, but on the Jaguar and Lexus systems, you have to set a switch on the actual GDO to tell it that your remote is learning, then you press is 3 or 4 times so it transmits it's code, then you set the switch back, so the remote can use it's static code while everything else has rolling codes. or that's my understanding at least.
--Dan
If you're unfortunate like myself that your garage door opener only accept 7-bit code, the "universal" garage door opener won't work
The so called universal opener only works with 8-bit openers
Tried that on M5, Audi, and Honda
1 - 4 of 4 Posts
