1 - 7 of 7 Posts
Was driving to work and this fault popped up. Anyone seem this before? Changed fuses #7 and #15 in the glovebox just in case but fault didn’t clear.
Need the code to verify the problem. Most likely it’s the occupancy sensor. You should see if your car had the recall and if it was fixed. Not sure what year car for recall.
I'll pull the codes and check the occupancy sensor.
I cleared the error codes with INPA before reading them. They did not pop up again after clearing!
1 - 7 of 7 Posts
