Hi all, some advice if possible?
I have been unfortunate enough to suffer the dreaded S85 crank rod bearing failure on my 2006 E60 M5. Having had the crank inspected, my only options are buying a second hand engine or rebuild the current unit. The spun / failed bearing on cylinder 7 dumped its debris into the Vanos oil pump which wrecked it, plus the crank has lost approx 1.5mm off it so no oversized bearings will accommodate the shortfall.
I have been quoted £7.5k for a complete rebuild that includes new OEM crank, all ten rod bearings and a new Vanos oil pump + soleniods. What could I expect to fetch if, after the rebuild, I sell it privately? I would hope to achieve between £20 - 25k but I am just guessing. The car has 87,000 miles and is in really good condition inside and out, so before I commit to these works I'd welcome any advice / opinions.
Thanks all.
Thanks all.
