1 - 12 of 12 Posts
just a word of warning in-case someone on here is considering the below.
Item Not Found
this is known as matter of fact
Link above no longer works.
Has anyone in Australia had their rod bearings replaced on their V10 M5 or M6 as preventative maintenance against the premature wear in these bearings? If so what did it cost and where was it done? Has anyone actually thrown a bearing and required an engine rebuild?
I'm contemplating doing some preventative maintenance. It seems they grenade around 150k's if they're going too. So I've got another 80k until I reach that, admittedly anecdotal, threshold but will pull the trigger well before. I've been sending technical's and processes to my mechanic here in Sydney for a few weeks.
I’m in the proses in doing mine at home. Using ACL bearings cost of $215 for the lot. I guess if your only interested in doing the bearings then I guess with bearings, new oil, new gaskets you be looking at around just over 300 bucks provided you do it your self saving over $1500 in just labor. It’s a petty straight forward job if you just doing the bearings.
I’m going a full engine upgrade including vanos gears, vanos like line, oil squirters, oil pump chain tensioner and a full 100km service. Parts in total $3000 AUD. Not so bad considering I payed Audi $1700 for a 50,0000 service that was just a oil change and filters.
Can anyone recommend me a good mechanics in NSW who can inspect my car and change all the fluids..? I have recently bought e64 m6 2006 but couldnt find good mechanic who specialises M6/M5 ..!
Hello,
Sorry for randomly messaging you..
I recently purchased a M6 (e64 2006) and I am located in Sydney..!
If you dont mind can you please recommend any good mechanics who can inspect my car ... and change all the fluids..?
Thank you for your time..!
Hello,
Opps I was meant to delete the bottom bits
Good morning muckman83,
Thank you for your reply and kindness !!
I just dropped off my car this morning...
Apparently my battery, brake pads will need to be replaced 😞
My car is on 81xxx kms now... if you could guide me how to change the fluids, that will be much appreciated! I might change them again at 100,000kms. (Will change engine oil more sooner)
I am still very new to the m6... (its been a week since I got the car haha) I am still learning what should be changed/maintained !
Thank you again for your time !
Keep an eye on super cheep oils
They just had a 40% sale on there Castrol edge 10w60
I picked up 6 bottles cause it’s so cheep and saves you in the long run.
Change your fuel filter and o2 sensors at 100kms
Being that it’s 2006 you gonna wana do all the engine updates and replace rod bearings
So vanos gears
Vanos line
Vanos pump chain tensioner
Oil squirters
I also went for a full service including fuel filter, new injectors, new charcoal canister, throttle body and idle actuator clean, new air filters, new spark plugs, new coil packs, new brake fluid. Maybe if your willing nee maf sensors.
Thanks again for your reply.
I will look out for engine oil sales !
Did you do all work by your self???
I might be able to change engine oil... but I have no idea how to pull engine out and etc...
Out of curiosity, what model year is your car? I was under the impression that the VANOS pump gear issues only affected cars until circa early-mid 2006 build?
1 - 12 of 12 Posts
