1 - 11 of 11 Posts
Got the engine out of the M5 Racecar today and was pondering how to mount the engine to an engine stand? Reason I ask is, the lack of support around the areas where you would mount the engine to a stand seems incredibly weak. I really don't want to risk breaking part of the block doing something like this so I figured I would check here first.
Thanks,
J
Could someone please detail how to mount the S62 on an engine stand?
Questions I have:
- Do those mounting bolts need to be sourced separately or are they found somewhere on the engine block itself?
- Where are the mounting points on the engine block?
- I've found a potential engine stand, but believe it only has provision for the four central bolts and not the ones on the periphery. Would this be a problem?
It sounds like the owner of that stand has lost the 4 adjustable metal arms which would mount in the holes you mention.
In that state the engine stand probably won't fit any block...
Premium Member
Questions I have:
1 Yes
2 See link to thread from 68FB
3 Yes, get one with adjustable arms.
1 - 11 of 11 Posts
