1 - 2 of 2 Posts
I've installed the scoops and blocked off the holes, leaving a small gap for water to drain. If the goal is to establish a semi-ram air effect, what about the breather hose? How will pressurization affect it? Should the air box be blocked off at that point, too, and a separate filter installed on it? Otherwise it would seem that the increased pressure would potentially presurize the crankcase.
Company Representative of RPI Power
Check out this thread: http://www.m5board.com/vbulletin/showthread.php?t=110560&highlight=rpi+scoops+dyno
Deknight was the first to plug the holes and we decided to test it out. These tests were done with a block off plate that we made. This allowed the factory airboxes to pressurize quicker. I dont think the breather will have much affect as far as hp is concerned. This does make for a great discussion though. :)
1 - 2 of 2 Posts
