Ok I have searched enough and no simple fix seems logical for my car. New Thread Time. First off Problems, then car history
Purchased car 2 months ago and on the drive back the SES triggered. When I bought the car the previous owner informed me that the car took a while to warm up, minute or so. The car was given a PPI and only thing found was a potential gasket leak for trans fluid that would need to be adressed at a later date. I had never owned a big V8 before and thought that these engines could just need to warm up to operate correctly.
Rough Idle on Cold Start (left off 5 or more hours):
Engine revs to ~1200rpm then slowly settles to 700ish. Car is un-driveable if not left to warm up for a minute (redline moves slightly higher, 2bars). The throttle is almost completely un-responsive, feels like drive disengages or no gas is getting to engine.
Pulled codes:
(CE) Misfire During Warmup, Cyl #2
(CF) Misfire During Warmup, Cyl #3
(D1) Misfire During Warmup, Cyl #5
(D2) Misfire During Warmup, Cyl #6
(A3) Control Unit Self-Test, master reset
(D5) Misfire During Warmup multiple Cylinders
(B2) Catalyst System Efficiency Bank 1
(B3) Catalyst System Efficiency Bank 2
(AE) Air Fuel Adaptation Bank 1
(AF) Air Fuel Adaptation Bank 2
Month ago engine revs to 1200 then stalls for first 2 cold starts. On 3rd it starts just as described above. I cleared the SES and pulled:
Currently the engine revs up to 1200 then drops immediately to 1000, no stalling, then slowly down to what appears to be 400 on the cluster gauge (i was panicking). The diagnostic menu, though, says 600-620rpm which to me is still low. I took it to a Foreign Auto Shop and they vacuum tested the car, no leaks, and drove it, saying it seemed fine. This was not after a cold start.
Next, I took it to a BMW dealer, they told me it didn't start up weird after sitting out in the cold all night. I have no idea what they looked at because it does the same thing consistently every morning. They recommended stock filters for my K&Ns. Replaced, no effect.
Just pulled codes again and got the same 4 above plus 69 (coolant temp plausibility). I ran the KTEMP test and got 80-84 after driving city for 10 minutes, Started around 49. I also did the MAF test and pulled 126 L/H. I plan to do the IATS relocation this weekend.
I bought the car (2000 m5) as the 4th owner with 49000 miles and all service records. All quick fixes were replaced on the car within the last 2 years and about 6000 miles, So i am at a loss of where to to go now. Services as follows:
NGK Spark Plugs (Nov '09)
Thermostat (Feb '10)
Coolant Temp Sensor (Feb '10)
2 x O2, post and pre cat (May '10)
Fuel Filter (May '10)
Bosch MAF (May '10)
2 x CPS, outlet inlet (May '10)
I have searched for these symptoms for about a month now and most of the advice says to replace the above sensors as a start to troubleshooting the problem. I wouldnt't think any of these have gone bad yet. Any Advice or direction? Sorry for the length
Pulled codes:
Bosch MAF (May '10)
