Why don't you go for this one ? :
http://www.m5board.com/vbulletin/e39-m5-e52-z8-discussion/149362-o-e-reverse-camera-kit.html
Lol !Ah, that's what was posted, ah well....
eas - 714.369.8524 | Reverse License Plate Camera with LED
Im looking into buying some sort of small camera that will stay on and that is waterproof so that I can attach it to my aux in / RCA video in to the M5.
Anyone have any opinions or suggestions?
Does this reverse cam connect via RCAs/aux in? or through the Nav unit itself?
european auto source - 714.369.8524 | how fast can we make your dream go, stop and corner?I looked at the link and the E39 M5 isn't listed as an application.
Exactly. The right side.oem is just clean thats why i bought one and got a good deal on it as well. KGB SSR where is the camera on your car is that a plate light hole or the trunk switch area?
Running the wiring through the rubber boot is a real PITA. I managed to push a bit of coat-hanger wire through the rubber boot first, then tied the wiring to it, and then smearing vasaline all over the wiring made it a lot easier to pull through.the wiring is not that hard. its all of 5 wires if i remember correctly(12v power, ground, reverse light, video + and -) all is done in the nav location. the worest part of the job is running the wires through the rubber boot for the trunk lid to the trunk and getting the camera to mount right as its not a super secure design. it will be finding all the parts thats a pain as it took quit awhile for me to find the used tv tuner/ant. but i have read that it can be done with a video switcher that you can get from bmw. all the info you need including part numbers are in a bmw camera install pdf manual.
and this is the only chance to do it(( veeery hardRunning the wiring through the rubber boot is a real PITA. I managed to push a bit of coat-hanger wire through the rubber boot first, then tied the wiring to it, and then smearing vasaline all over the wiring made it a lot easier to pull through.
