1041 - 1060 of 1125 Posts
Anyone from Austin TX have any experience with reprogramming would like to do this to my 2010 M5...
My mechanic and I did this tonight. Its amazing how much of a difference this makes!
I like it only thing I don't like is the start off in D2 gets annoying as the car bucks if you don't remember to have it in 1
Mine starts in D1 (the shift timing thingy)and does buck or just drift when switching from reverse if i froget to change it. Small price to pay for the added benefits of cleaner shifts and improved launch control.
Update, these appear to be relevant Daten files, i found them today with a google search. They aren't mine so I cant vouch for them, if anyone else can verify they are or are not correct that would be awesome.
https://mega.co.nz/#F!h48UlKiI!VWXtthp41iwK6Z5sPjFGCA
I have downloaded my latest daten files from there and they seemed to work when i was programming my aux input
Anyone in Denver, Co on this thread that can do this, ill pay you for your time, lunch too! Let me know! Thanks!
Beau 720-838-95 ten
I successfully re-flashed the SMG control module on my 2007 M6 a few days ago, so I thought I would post my experience here.
After reading this thread, I made sure to have a good power supply for the effort.
I Purchased a TEKPOWER TP50SW 50 Amp 9-15 Volt power supply from Amazon, it has adjustable voltage, I set it to 14 Volts for this session.
I followed the procedure from the PDF that the OP linked to and used the Euro Part Number listed for the M6 (Version 3).
I received the the successfully updated message after completion of the flash.
I verified the software version in INPA, shown below (EGS shows Euro M6 software part number 7842210 installed).
I already had the BMW Software and Cable for use with my E65 ($20 cable from Amazon that has worked great for many years).
The only extra expense for this project was $165 for the power supply, and $20 for the jumper cables used with the power supply.
This update definitely makes a huge difference in shift quality, the old US version of the software was so harsh at times that the rear end of the car would clunk during shifts, I have not had any clunking since the update.
I have also verified the 4K launch control was active, much better than the crippled 1.5K US version.
All in all, definitely worth it!
Subscribing to this thread! I'll be using this guide later ;)
