1 - 1 of 1 Posts
The Geneva Salon 2004 Premiere of the CC-R
"It's the fastest car we've ever tested"
"It is my favourite supercar! You just want more and more."
The sentences comes from British national Jeremy Clarkson of Top Gear from 2003. A man that is quite selective when it comes to cars outside the British Isles, yes we BMW M enthusiasts have noted that. It was fast. Very fast. Faster than the previous leader, the Pagani Zonda S, with it's AMG-powered V-12.
So where in Modena, Italy is this supercar made? Near Pagani's factory? Around the Bugatti EB110 / EB110SS facilities? Close to where the Cizeta V16 was built?
No. In Sweden. Where Saab and Volvos once were built. This sounds like music to your ears, especially when you come from Sweden where manufacturing of fun cars is a rarity. Fun and fast supercars is VERY rare as well. Say "Hej" to the Koenigsegg CCR!
At Geneva Koenigsegg launched an R-version of the first Koenigsegg, the CC8S. The Koenigsegg CCR has all the features of the CC8S but a refined design of the side air-intakes, different headlight arrangement, a revised rear-design, larger brakes as well as new front splitters. Most importantly it have a much more powerful engine that produces 806 HP compared with the 655 HP of the standard model. Torque is up from 750 Nm to 920 Nm and it has a dry weight of 1180 kg.
A quote from the official brochure: 0-135 mph (217 km/h) in 10 s flat. 0-100 km/h in 3,2 s. Top speed 395+ km/h (242 mph). Quarter mile: 9 s, trap speed 235 km/h (146 mph). Braking 100-0 km/h 31 m. It's height of only 1,07 m reduces the frontal area and helps the Koenigsegg attain a remarkable top-speed.
The weight of the chassi module is only 62 kg thanks to the use of 21 layers of carbon fibre and the torsional stiffness is 28 100 Nm/degree. Compare this to the stiffness of a Porsche 996 Turbo Convertible with 11 600 Nm/degree. Notice that the Koenigsegg also is in part a convertible with a retractable hardtop. For reference the Porsche 911 Turbo has a torsional stiffnes of 27 000 Nm/degree and that is not a convertible. This offers excellent safety to the driver and passsenger, as seen in accidents during Formula One. Furthermore, the rigidity is also very important for the handling of the car.
Four fuel tanks are placed so that two are on each side of the car for optimum balance at all times. Parking sensors (PDC) are optional (It's true!).
The engine is a 4,7 liter V8 supercharged by a Lysholm-type compressor and weighs 215 kg. The boost-pressure is 1,2 bars and redlines at 7600 rpm. The exhaust system is on titanium on the CCR version and stainless steel on the CC8S. Notice the rearwindow with integrated third brake-light.
The small air-intake in the front is for cooling the brakes, while the rear system is supplied with air through vents under the car. Most of todays mid-engined supercars have huge air-intakes and outlets at the front of the car, making them nervous at high speeds. The Koenigsegg has it's aerydynamic pressure point behind the mass centre of the car, makes it more stable the faster it's driven. The xenon-headlamps have a slightly different design on the CCR than on the CC8S.
The front and rear brakes are 6-piston calipers developed especially for Koenigsegg by AP-Racing 362 mm diameter ABS-assisted. The CC8S has 4-caliper brakes in the rear. "The ABS-system is very much on the sporty side. It locks with some slip through the whole process making it very efficient. For a supercar I think it is a correct strategy not to make the ABS too intrusive yet still allow the driver braking control instead of letting the ABS take over too early." according to test-driver Loris Bicocchi. Koenigsgg has chosen to go against the currently trend with ceramic or ceramic-composite discs. Such materials are new and exciting, but has as of yet not proven neither as reliable nor as subtle as using steel alloy for brake discs.
The wheels ar emade of magnesium. Notice the rear lower diffusors, similar tecnique on the E60 M5. The wheels are Michelin Pilot Sport that can withstand speeds to exceeding 400 km/h. 20' wheels in back and 19' wheels for front of the CCR.
Beautiful interiour tailored in Alcantara, leather and carbon. Notice how close the gearshifter is to the wheel. I may look awkward but it is the best possible position for a shifter: as close to the steeringwheel as possible for minimum traveltime of the hand. The seat-cushions are made of Nasa-developed Tempur material.
The difference between the man and the boy is the price of the toy...
Moonroof a'la Koenigsegg.
Notice the bmwm5.com decal!
This is the Koenigsegg CC8S on a Swedish winterroad and the upper right is during Gumball 3000 2003 at the start outside the Fairmont Hotel in San Fransisco. Notice the bmwm5.com sticker!
16 cars have been delivered to customers as of March 2004 and Koenigsegg is working hard to until the summer to deliver the 20 more that are ordered.
If it is not evident I was very impressed by this car. The first journalist that will drive the CCR will be Tiff Needell which will be very interesting, since the CC8S was such an success for Koenigsegg with Mr Clarkson behind the wheel.
One thought this autumn is to team up the Koenigsegg with the E60 M5 on the airstrip which is just next to the Koenigsegg factory. I know the M5 will loose but it would just be interesting to see with how much... So I hope we haven't seen the last of Koenigsegg for this year!
Detailed specification
SPECIFICATION KOENIGSEGG CCR
PERFORMANCE
Acceleration: 0-100 km/h (0–62 mph) 3.2 seconds.
Top speed: 395+ km/h (242+ mph).
Standing quartermile: 9 seconds, end speed 235 km/h (146 mph).
Braking distance: 31 m (100–0 km/h)
Lateral G-force: 1.3 G
Fuel consumption: Highway travel: 13 l/100 km
Combined: 17 l/100 km
BODY
Two-door, two-seater with removable hardtop stowable under the front boot lid. The body is made of preimpregnated carbonfibre/kevlar and lightweight hard-foam sandwich reinforcements.
DIMENSIONS
Ground clearance: 100 mm (3.9 inch)
Fuel capacity: 80 litres (17.6 gallons)
Luggage compartment: 120 litres (26.4 gallons)
Dry weight: 1180 kg
AERODYNAMICS
Cd. 0.297. Frontal area 1.825 m2. Completely flat underside of chassis.
Venturi tunnels at the rear of chassis/body.
CHASSIS
Semi monocoque made of preimpregnated carbonfibre and with honeycomb reinforcements for added stiffness.
Front and rear suspension: Double wishbones, adjustable Öhlins Racing gas-hydraulic shock absorbers, pushrod operated. Anti-roll bar. Electronically adjustable ride height.
Front brakes: Ventilated discs Ø 362 mm, 32 mm wide. 6 piston light alloy calipers. Power assisted. Koenigsegg Advanced Control system.
Rear brakes: Ventilated discs Ø 362 mm, 32 mm wide. 6 piston light alloy calipers. Power assisted. Koenigsegg Advanced Control system.
WHEELS
Koenigsegg magnesium alloy wheels with centre locking.
Front: 19” x 9.5”
Rear: 20” x 12.5”
TYRES
Michelin Pilot Sport 2. Unidirectional with asymmetric tread pattern.
Front: 255/35–19” (Y)
Rear: 335/30–20” (Y)
STEERING
Rack and pinion power assisted steering. 2.7 turns lock to lock. Turning circle: 11 metres.
ENGINE
Type: V8 cast aluminium, 4 valves per cylinder, double overhead camshafts. Cam cover of carbonfibre.
Displacement: 4.700 cm3.
Compression: 8.6:1
Weight: 215 kg
Lubrication system: Dry sump with unique oil spray piston cooling. Oil cooler.
Oil: SAE 5 W/30 fully synthetic racing.
Oil tank capacity: 12 litres (2.64 gallons)
Induction system: Sequential, multipoint fuel injection. Lysholm twin-screw supercharger with 1.2 bar boost pressure. Intercooler.
Fuel: 98 RON unleaded.
Ignition system: Direct coil on plug. Transistorised.
Power output: 806 bhp at 6.900 rpm.
Maximum torque: 920 Nm (678 ftlb) at 5.700 rpm.
Maximum rpm: 7.600 rpm.
TRANSMISSION
Specially developed 6-speed gearbox by Cima. Incorporated internal oil pump and oil cooler. Torque sensitive, limited slip differential.
Clutch: Dual Plate, organic or cintered Ø 215 mm (8.46 inch). Oil-cooled and electronically operated.
EQUIPMENT
In standard mode the car is very well equipped with many items that competitors have as options. Many customers, however, want to further equip the car. Therefore we can offer a list of customer options which should fulfil every demand.
Standard equipment
Detachable roof panel
Climate control
Electric rear view mirrors
Leather interior
Central locking
Electrical windows
Alarm with immobilizer
Toolkit
Driver side airbag
Power steering
Hydraulic ride height control
Servo assisted brakes
ABS
Traction control
Stereo with CD-player
Tyre pressure sensors
Car cover
Exhaust system in titanium
Customer options
Parking sensors
GPS navigation and/or tracking system
Telephone system
Rearview camera
Aluminium rear light casings
4-point safety belts
Sequential gearbox
Tailor-made suitcases
Custom colour leather interior
Custom paint colour
Additional noise insulation
Carbonfibre rear twin fin wing
Carbonfiber front splitter
Ø 378 mm brake discs, front
1 - 1 of 1 Posts
