Replacing bulbs in Alpina display?
1248 3
Hello all..
I have recently changed the background of the oem dashboard and bought it on ebay.com ,, rebuildt,, 150 $ ((brand new from Buchloe was 900 € ))and works perfect.. on the oem i couldnt get water temp and so on.. the fuel meter was also really playing with the needle up and down ,,,ouichouich
But,, the digital gauge -->>
oil heat ## oil press ((bar )) -------boost pressure((bar))### diff heat °c
on the right side were boost and diff temp is ,,,the instrument is hard to see
so i opened it and there are no lights on the bulbs,,((2 of them))
arghhh,, they are welded or whatever you call it and i want to ask you folks out there,, is it anyone who have been in a similair situation,,
maby one of the lines are cracked or damaged .. i will use a ohm measure to find out,, but if not should it be a problem to change these bulbs ??
i hope somebody knows something about it
BEST REGARDS
1 - 4 of 4 Posts
I changed them on CJs car. You have to solder the light off the print. Easy job if you can solder/weld of course. I welded it off and went to an electronic store and got new ones. Changed them and it worked again.
Change them all if you do.
Ok,, thats what i thought,,
Thank you ..
1 - 4 of 4 Posts
