1 - 5 of 5 Posts
Hi, any recommendations for alternative replacement ignition coil brands rather than OEM?Have seen ‘Delphi’ and ‘Bosch’ brand online. Huge price difference between OEM and alternative brands.
Any idea who manufactures the OEM ones ?
Bremi is OEM, if you are planning on changing them as a PM I will buy the ones that come out. I wait for a misfire and then throw one at that cylinder.
Thanks mate, actually have a misfire, so planning just to replace the one...when I figure out which one it is...
I always thought due to high resistance... they can go bad over time + high miles even if they don’t misfire.
is that not The case?
if you're in a bind, oreilly house brand coils are good. should be cheap too. they may come apart when you try to get them out without much experience but their electronic is good. i'd lube it with diaelectric grease before install.
1 - 5 of 5 Posts
