Today's update.
I go to the dealer and of course my service guy is not in, there are no notes in the system, and nobody can find any paperwork at all regarding any tests.
I ask for a technician to speak with me, but my requests were declined.
I refused to pay for the services until I recieved all the documentation, they actually let me leave with the car and promised to get some things out to me in the next few days.
At this point they are advising to just drive it for a few hundred more miles to see if the problem persists as they may have fixed it, despite telling me the other day that it was failing all the tests they ran on it. According to the conversation I had the other day, Bank 2 is passing whatever test 80% of the time, and Bank 1 is only passing 20% of the time.
I looked up old invoices and here is the timeline of events based on them.
December 05:
Took car in for 90k service, also the car had begun to vibrate badly at idle and felt like it lost four cylinders, dealer made the following notes on the bottom
-check engine/service engine soon warning dsplayed, check faults, has 13 faults set. Only one fault is present, servotronic fault. The T-stat has set faults and car did not warm up. Clear all faults to see if any come back after repair tech 630 starting point---- T150 interogate fault memory of DME, found F/C184 for inlet Vanos function bank 1 stored. Cleared fault and perform vanos function test, failed test for bank 1 but passed for bank 2. Recheck fault memory f/c 184 stored again. Replace bank 1 vanos solinoid pack and perform Vanos function test, still did not pass test but did not log f/c 184 again. Road testded 6 miles and re-check for faults, no fault stored. If ault 184 returns, will require furth diagnosis
key items replaced were a Solinoid and gasket, coolant thermostat, servotronic control unit/wiring harness, torque converter (?),
April 06 the following notes were on the invoice
-Owner states engine runs and idles rough/service engine light on, car in limp mode
Dealer notes- Replaced bank #2 vanos solenoid pack, confirmed concern. Checked faults and found many faults. The Vanos function bank #2 is currently present. Performed a Vanos test and the car did not pass. Checked the position of the cams and found that the bank #2 intake cam is not in the correct position. Replaced the solenoid pack and now the car is running better. I will have the car test drove and recheck the adaptations and the faults if there are any. The adaptations are starting to even out. There are no faults after a couple of test drives. The car may still need a fule injector service but we should wait to see if the adaptations get better, as of now they are much better than before.
December 06 invoice- Owner states check engine light is on....again.....car in limp mode, see file
Dealer notes on invoice - check for cause of check engine light, check function of Vanos unit with GT1. Vanos on bank 2 failed test, test module indicated to verify correct camshaft timing. checked timing of all camshafts, no problems found. Replace faulty vanos unit for Bank 2. Replace original vanos unit for bank 1 also.
An RMS leak was also repaired at this time.
For some reason I don't have the invoices with the CPS replacements on them though, unless they are burried in more pages here, however they were replaced as well.
I'm not sure what else to do, but will find out more when I can get test results later this week. I'm curious why they would say I need major engine service, but to keep driving it to see if it comes back.
