1 - 7 of 7 Posts
as above ive googled etc no help
Wont unlock or lock car
If i open with good key and insert non working key in car it still starts it
What do i do to fix it? Thanks
Non Comfort access Key Fobs do not have a removable battery. Did you cut the fob open to access it? If so, i suspect you may not have used a rechargeable battery, which is required since the Non-CA FOB is charged in the key slot. Another potential problem could be the solder points on the new battery, If you did replace with a rechargeable battery, check the solder points carefully for cracks or overflow. If both the above are good, maybe your new battery is just dead and needs to charge in the key slot. A couple hours driving should confirm that.
^ yeah I was under the impression the non CA keys don't have removable batteries and you just slot it into the key slot when driving to charge it
I would check the key status in ISTA. There you can enable, disable and check the key battery and at least determine if the key is communicating with the car. If not it may be time for a new key
Ordered 2 new keys instead
I was hesitant to replace batterys in it, as has to be glued back
1 - 7 of 7 Posts
