1 - 5 of 5 Posts
I want to remove the plenum chamber today to have a proper look at the rocker cover gaskets and any other leaking possibilities. How long does removal and replacement take? (I'm competent but not gifted!)
Any parts that I will need to replace with new ones (seals etc)?
make sure that you get the upper plenum gasket with the 4 o rings.
I just removed my plenum last week. Pretty easy, just a zillion nuts to undo; ie, plenum cover, air horns, and plenum bottom.
I used a battery-powered variable speed drill with a socket attachment to spin the nuts off and on, saving a ton of time. Just be sure and do the final tightening with a regular socket to get the right "feel" for when the nut snugs up properly. Aluminum is easy to strip out.
Bennji
1 - 5 of 5 Posts
