I've removed the panel many times. The easiest way I've found is to pry the cover off the lighting unit (the plastic cover closest to the windshield). I'm able to do this by just using a fingertip on the driver's side short edge of the cover. Once this is popped off I can simply pull down the light housing, it's just held in by two spring clips. Then I can slide the alcantra (or whatever material it is) cover with the Homelink transmitter and sunroof control towards the front of the car and down. Reverse to reassemble.Tom Burns said:Hi,
Could anyone please tell me or point me to where I could find out/see how to remove the overhead panel which contains the lights/sunroof switch?
