1 - 3 of 3 Posts
Help needed.... I search several sites only to find vauge references to connectors, the 'white' wire, etc... I tested for switched signal power, but can't find it. Can anybody show a picture and exactly which wire this is.
Thanks in advance!!!!!
Discussion Starter · #2 ·
BUMP....
More info. I read that there is a white wire (remote turn on lead). Is this no the 'radio' module, on the 'amp' module? I did see a white wire on the radio that I tested. I put a small needle through the wire and used a Digital Multi Meter to measure volts (with ignition switch on/off). I did not get any voltage. I also tested a few other wires, No Luck.
In Need Of Help - Please.... :M5eyes:
Ok, I found it. The large 15 pin connector on the Amp, the white wire is switched power. Don't know why my earlier test did not prove this out. Oh well, perserverence prevailed. Subs now work..... :M5thumbs:
1 - 3 of 3 Posts
