Refurb Rear Wheels or get a 2nd set - Dilemma!
1088 Views 13 Replies 7 Participants Last post by  ard
Trying to decide whether to buy two scuffed-up rear OEM rims and get them refinished! Has anyone done this before and if so, how were the results and can they match to existing color and spec for fronts (my front ones are relatively new!)
Any suggestions fellows?
:deal:
1 - 14 of 14 Posts
Find a good rim shop and you will have no problems. Check other members nearby for recommendations.
Colour matching is not easy, it helps if you can give them the fronts at the same time, then pair up the front and rear that match each other closest to put on the same side of the car.
Wheels America is the local Dealerships refurb company.A friend thats a 22 year BMW mechanic says the only thing they can't match is the paint.He says he can't tell where the ding was after they fix them.$129 without the tire/$149 with and they fix them overnight.:M5launch:
i thought the shadow chrome was essentially unobtainable in the US? no?
Is this stil the environmental issue with the overseas Shadow-Chrome paint process and paint that BMW uses or is this just a simple case of not shop out there being able to replicate this process? I guess safe bet is to take a couple of pics of my front rims and have the shop of choice match as close as possible the front color to the back! That way, they are not out of whack! I noticed that mine in the rear are lighter than the front so this will probably will be a summer or fall job once I take a vacation and send these puppies to a shop for refurb during my absence.
Good thing I kept a pair of 18' m-parallels off my old 528i!
· In Memoriam
You really ought to try a search ... many threads on this issue ... although some places may have mastered the technique by now.
The OEM paint is NOT obtainable in the U.S. for environmental reasons.
Don't supply a picture, they do not accurately reprent the color.
I would suggest having all 4 wheels done at the same time, for consistency.
Agree with you.
What are the feelings on having them chromed? or is that a MB thing.:M5launch:
· In Memoriam
Agree with you.
I had my first set polished and clearcoated. But, I bought another set of new OEM wheels (anal), so the original set (which look almost the same as new) are sitting in boxes in my garage (never mounted). It was MORE expensive than chroming. I just didn't like the look of chrome wheels on an M5.
Wheel Collision Center in Bath, PA might be relatively close to the OP... give them a call.
IMHO, having two wheels on the same side done at once is more that adequate-
· In Memoriam
The original post mentions two rear rims ...
Discussion Starter · #12 ·
That's correct! My front ones are fine!
In order for them to match my front ones to rears, it would require someone who has done this numerous times in the past and successfully! I know pictures (no matter how clear or detailed, don't always do justice) but it does beat buying 4 new rims!
I will do my homework and decide which option works better and does the least pocket damage!
Or the other alternative is to buy 4 SSR GT3's which I really like (staggered of course!) - well, maybe!
· In Memoriam
Based on posts here over the years, I would seriously consider Wheel Collision Center in Bath, PA. But, I would still have 4 done.
1 - 14 of 14 Posts
