1 - 4 of 4 Posts
Hi guys, changed the spark plugs on the beast tonight, all went well as far as I was concerned, until I started her up. I ran INPA and found the following. image.jpg
Any ideas? Maybe I haven't pushed home one of the leads, but I doubt it. I'd appreciate any inputs!
T
Guest
Were they installed correctly?
Pull plugs and check
Then check coils and make sure they are installed correctly and plugged in.
Not to go off subject but Troy I am awaiting some info and parts from you.
So I checked all plugs and leads tonight and everything seems nice and tight.
I then swapped the ionic current control models and got the following list of codes.
I'd really appreciate some help in deciphering these and finding the cause. Before the plug change all was well with no faults whatsoever.
2AFB
2AFC
278F
2712
2713
2B3A
2B57
2796
It's worth adding that the entire exhaust system from the primary cats is currently off as I'm doing the muffler delete mod. Could this be part of the reason. Thanks in advance for all and any suggestions!!
1 - 4 of 4 Posts
