1 - 3 of 3 Posts
Hi, I'm hoping someone can help. I have a 2008 M5 and recently I noticed my rear passenger side seatbelt is wet (when you pull it out.) When I check the inside of the car everything is dry. I even pulled the trunk liner on both sides and all looks dry. The times it has occurred my car was on the driveway facing the garage door. The drive way is on a slope which means water would roll down towards the back of the car. I am baffled by this one issue, so any help would be appreciated. Thanks!
I would open your moon roof and pour water in the tracks at each corner and verify the water is draining out onto the ground behind each tire. You may have a drain tube problem. This is an expensive and serious problem in the E61.
Thanks, I will give that a try...Hopefully it's that and I can clear/correct myself...
1 - 3 of 3 Posts
About this Discussion
2 Participants
Hayward135
BMW M5 Forum and M6 Forums
Full Forum Listing
