Guys
As you might be aware, my 540iLE came with the full 1995 M5 suspension, including EDCIII.
The rear is feeling very hard and unpliable, bouncy even. There is no noticeable change in this feeling - even when I switch between S and P. In any other car, I would conclude that the struts are shot.
Visually they appear to be fine with no sign of leakage (they have done around 105,000kms, or 60,000miles) and there are no check control warnings.
Is it likely that the struts are not working (and require horrendously expensive replacement), or could some other fault explain the problem?
Thanks in advance.
Cheers
Thanks in advance.
Cheers
