It turns on automatically upon startup if the outside temp is below a certain temperature, whether or not it's needed. Mine does anyway, so did my E46 M3 vert.
It only started after recoding my IHKA Module per Progmans measure plan.Hmm not sure mine does not turn on automatically, and i have been -20 degrees
What is Progmans measure plan? I am with RVT on this one, my has to be self pushed. Maybe we can figure it out tomorrow RVT.It only started after recoding my IHKA Module per Progmans measure plan.
The measure plan was automatically determined by progman, if you have a progman setup do the following: LOAD SW > IHKA > Encode.... and it'll take care of the rest.What is Progmans measure plan? I am with RVT on this one, my has to be self pushed. Maybe we can figure it out tomorrow RVT.
Come by my house and I'll recode your IHKA, hopefully that'll do the trick.If you figure this out, I want it. I would like nothing more, than the rear defrost and heated seat to come on when I start the car below freezing.
Glad to hear it was fixed without having to visit the dealership!I will should be heading to the big smoke next week. By and by fixed the noid it was plugged and weak solder joint. If you had not mentioned the solder again I am not sure I would have looked. Thanks
