1 - 16 of 16 Posts
Did a search and didnt find the info I needed. What weight / viscosity do you use for tranny and rear diff. as well as quantity for both. Any help would be appreciated.( oil used and amount for both) Thanks Jim
I don't use Redline, but I'm going to answer your question anyway as best I can :)
1. Differential Weight: 75W140, Tranny: Not sure. RP is Synchromax, but that doesn't help much, does it :)
2. 2 quarts each.
d-
ps. As a side note, search for "Redline transmission". That should bring up more information than you ever want to read, including several documented concerns that Redline and our transmissions are not compatible. Whether that has ever been definitively proven I do not know since I use RP.
EDIT: Apparently there is no proven concern with Redline and the BMW transmission (unlike the Supra tranny).
As staed - Diff is 75W 140 and takes 1.6 litres
Gearbox takes 1.75 litres. Viscosity escapes me.
Super Moderator
it has since been proven that our getrag gearbox has some significant differences compared to the toyota supra getrag gearbox, so redline should be fine. I've run it in my gearbox and diff for >50k miles without issues. I changer it every 25k miles or so.
I use the Redline MTL in all my cars, on the m5 the MT-90 is closer to the stock gearbox fluid(viscosity) but the MTL is much better in the cold weather so I leave it in there all year round
I race my car occasionaly and I never grind a gear even when speedshifting
and like everyone else said 75w-140 for the rear diff
I guess more specifically What is the name on bottle like the MT-90 for tranny or D4 synthetic for. I want to make sure I have ordered the right thing and the quantity for both.. Thanks for answering...:blabla:
Discussion Starter · #8 ·
Shill account for CNS Racing
I know an E39 M5 owner that has recently had his transmission blow up and he was using Redline oil. No proof that it was the oil just an FYI.
I wanted to change my trans and dif to red line but was told by the service manager that it would void my warranty . Has anyone had issues with red line oils in M6 smg or dif ?
I think you may have a better chance of getting an appropriate answer by posting in the M6 forum.
I've used Redline in the differential of my e39 M5...
and Royal Purple 01512 Synchromax in the manual gear box.
That's odd. Most trannys that blow up are using BMW OEM oil. :tonquesmilie:
1 - 16 of 16 Posts
