1 - 20 of 20 Posts
Hi to all, from looking at some of the B8 related threads it appears that there is a lot of knowledge floating around out there!
I have put a deposit on a 1998 B8 with 98KKM on the clock. I was wondering if there are any common faults that I should look for on this machine, one of you mentioned eratic idleing in another thread I was wondering what that was symptomatic of?
Also if anyone had any knowledge about the history of car 75?
Would really apreciate any help / information that anybody could provide.
I look foward to contributing to the site when I offically own the vehicle.
Is it a coupe or saloon?
Where are you buying from, out of interest? Presumably ex-UK? Otherwise, I'd advise you to get Phil Crouch to have a good look at it (you can reach him through Birds) - he's worked on 3 different UK resident B8s and knows his stuff...
On the other hand, Phil, I know you're on here, so say hello!
It is a coupe with cloth Alpina interior. it is a UK registered vehicle via a private seller.
Thanks for the link to a previous thread on what to look for. I assume you mean Birds Tuning?.. Many thanks for the advice I may seek an inspection..
Where abouts in hampshire are you b8uk? I am near guildford,
I recently bought a b8 with 90k km on it, and the only problems i have had are:
The CD player doesnt work most of the time.
Erh and thats it.
The b8 is a great car,
Could i ask what is the asking price of the car? PM me or email me off board if you like.
Hi
I am based in Horsham, West Sussex. I have a B8 Touring, Lucie, purchased from Hythe. Nothing major, part from an odd rattle from the dash under acceleration and interesting like Adam, the CD works intermittently. I use an excellent garage, MJF Engineering, run by Mark. He is based at Capel in Surrey, 01306 713232. He checked out Lucie before I bought her. As you are based in Hants, it is quite alot closer than Birds. I would be interested to hear what sort of money you plan to pay for your B8. Hope that helps. Cheers, Joni P
Discussion Starter · #9 ·
Thanks for all the info so far.. Thanks very much for the history on the car.
I now have the B8 and will post a couple of photos soon, it is in a Blue Individual metallic finish with Alpina cloth interior. Anyone ever had a problem with the auxillary drive belt tensioner? as I have this week.. its shreaded two belts already.. sorting that at the weekend.
Would welcome any advice on clutches for this machine as I think its needs replacing.. is it a standard E39 540 clutch? also the disks and pads need replacing allround. As I understand it the rears are standard M3 calipers disks and pads and the front are something bespoke? is that correct? I notice that there have been discussions regarding uprated pad compounds being specially produced for this car, can anyone guide me in the right direction for a decent set of uprated discs and pads?
How many B8's are out there in the UK at the moment? 5 as I understand it?...
Very pleased with her so far, staggering performance.. stagering. I think Kees might be right when he said that the 1998 models were rumoured to have 350HP, I minced a M3 Evo yesterday without even trying. The torque is just superb..
JoniP said:
Hi
sorry to hijack didnt know you used mark for your work and i second that hes rebuilt quite a few alpinas so yes your in good hands.
Hi Kees,
any informatin on what the difference between the early and the later models was to explain a possible increase in power ?
Cheers, Alex
AlpinaB8 said:
The reason might be that the newer alusil engine has lower internal friction then the nicasil = less loss of energy
I thought Alusil has a HIGHER friction coefficient than Nicasil - hence why they originally used Nicasil...?
Perhaps there's a difference in the exhaust manifold / piping? That's what held the older cars back.
As I heard from my mechanic the nikasil block pistontrings has higher preasure ageinst the walls of the block then the alusinl, hense the higher friction.
There hasen´t been any exhaust updates to the B8 according to Alpina, when I asked if they did any modifications to the engine, gearbox or drivetrain during its lifespan. They answered that no such modifications where made. (except the nikasil/alusil change)
The B8 E36 is restricted to 333 PS and 470 Nm...there are no differences between the modelyears. The engines in the E34 made 340 Ps and 347 PS in the E39s....the engines are restricted by the small exhaust manifolds due to the missing space in the E36 engine bay....
You can take a normal 540i E34 clutch-that will work perfect.
Just change your head-gaskets to the ones of the X5 4.6 is. these are made of metal instead of the original organic ones. A head-gasket damage will cost you a cylinderhead and a new block...i've seen 8 engines dying by this way
You should change some rubber bushings as well-rear shock-absorbers, rear control arm, Front shocks mounting...
The waterpump can also be worn after this time-mine left in a 13km long tunnel in Switzerland...not very funny at all.
Premium Member
The engine made 340hp in the first series of the E39.
I have no intention of introducing rumours. My source is one of the specialists on the B8.
Discussion Starter · #18 ·
Thanks for the advice Alpinab846, I am having the vehicle inspected next week with a new clutch, bushes, tie rods + ends being scheduled. I will consider getting the head gasket updated and well as pre emptively changing the water pump.
Yes, I had a problem with the belt tensioners. Had to replace all of them.
for the brake rotors there is no alternative to the factory Alpina/Lucas rotors. Alternative Pads can be custom ordered from EBC in different compound qualities. I ordered a set of Yellowstuff R pads.
read here:
http://www.m5board.com/vbulletin/showthread.php?t=50817
here's my incomplete list of stuff I needed to replace so far:
- brake rotors and pads (calipers seized after last winter, causing melted pads and warped rotors)
-replaced all belt tensioners
-new water pump
-new starter motor
-new batterie (the old one died this winter)
-head gasket replaced with metal X5 4.6 parts
-replaced shocks
-replaced control arm bushings
-replaced rear shock mounts
-replaced front shock mounts
-replaced front control arms
-replaced tie rods
-fixed leaking headlight washer nozzles
-replaced failing air temperature sensor in side the brake air duct
next:
-replace rear trailing arm bushings
-repaint the complete front because of stone chips
read here:
-new water pump
-new starter motor
-replaced shocks
-replaced tie rods
next:
They do seem to go through starter motors at quite a rate....
1 - 20 of 20 Posts
