1 - 14 of 14 Posts
As in are you rotating the fronts side to side? Why or why not?
Can't seem to find a consensus. Would seem to make sense for overall greater longevity.
TIA
Are the tires directional?
02' Carbon Black M5 & 11' Alpine White 335D M Sport
I did not do any rotations on my current set.
25K miles on the fronts
11K first set of rears (Costco deemed factory defect, I say over inflation but wasn't going to argue with their $175 credit for 2 new rears:applause:)
Fronts have cords showing on both edges, two Auto X days, lots of canyon miles and worn control arm bushings. New parts will go on before I put another set on and get an alignment.
I will probably be rotating the next set and hopefully grab a few extra miles out of them.
I have a square setup with Pilot Super Sports. I'm rotating front to back only. I read somewhere that rotating side to side makes the tires slippery for some reason. Not sure if there is any validity, but since the rears wear on the inside and the fronts wear on the outside, I figure I'm getting the intended results of rotating either way.
Nope. They are not symmetrical.
Agree with above. PSS are not symmetrical. Maybe I'm missing something, but I thought this precluded rotating side to side.
You're correct: asymmetrical tires cannot be rotated on the same axle. Well, you can do whatever you want with your tires... but you're not supposed to swap these. They're running in suboptimal conditions now and you're not getting the performance you paid for. If longevity is an issue, buy symmetrical tires.
Discussion Starter · #9 · (Edited)
Curiously, what are you referring to here: "They're running in suboptimal conditions now and you're not getting the performance you paid for" (?)
Regarding the original inquiry (PSS rotation on a staggered setup) & yep, its turning into the typical oil thread, many opinions exist both here and on numerous other forums such as below, with minimal resolution. Best as I can decipher and so long as 'Outside' remains the same, fronts 'can' be swapped side to side.
Tire Rotation for Michelin Pilot Super Sport - E46Fanatics
Reactions: sor118
Correct.
Reactions: vics
I'm confused. With flipping them as such on the same axle, doesn't that invert the tread direction?
PSS are not directional tires. That have no rotation preference.
Reactions: vics
Okay.
So if you flipped them on the same axle to maintain the "outside" designation, you've accomplished nothing. Why would one want to do this?
The inner camber wear, for example, will still be on the inside.
Discussion Starter · #14 ·
Okay.
Road crown, tech's built in alignment, suspension inequalities (wear) per side, driving & cornering habits, etc., all point to the fact that no two tires will ever wear identically, hence the rationale for rotation.
Reactions: paul88
1 - 14 of 14 Posts
