I have a small leak from the top shaft, actually identical to this, but more importantly a ton of axial play on the rack shaft itself - if you yank on the front wheels in the yaw direction, you can see the rack shaft move forward and back in the housing (and makes sort of a clicking noise).
I can also feel it while driving, large slow bumps have a pronounced metal-on-metal feel coming through the steering wheel and I've had persistent high speed vibration that comes in and out, even though my car's got brand new control arms, inner/outter tie rods, sway bar links, front wheel bearings, steering shaft &shocks with less than 50K miles on them and the alignment and wheel balance are spot on. I'm guessing that at speed the extra play induces oscillations in the toe-in as the rack shaft bounces back and forth.
Tightening the preload screw did not fix this by the way.
Now you've got me curious.
If I stab the brakes, sometimes it feels like a combination of small alignment issue and a worn bushing somewhere - the steering wheel jerks (slightly) to one side. It's not a big deal, but I was thinking I'll get around to getting an alignment and checking all the contact points.
Possibility of an internal issue instead?
If it feels like the front wheels move back when you just tap the brakes hard and let go, it's the tension strut bushings. The rack thing comes through the steering wheel like a metal clunk, rather than gummy suspension response.
How is all yours turn out? I also looking for one but out of stock. My car is 2007. When I search Realoem the part number 32102283767 is from 3/2005 to …….2010. Curious why BBB website different part number for different year.
Can I grab anyone other than 2007 to fit in my car? Any idea? Called to their technical & support and they have no idea why different part number in their website.
Most of their rack do not have the black plastic cover seal connecting to steering column. Do I need to be removed from my current plastic cover and placed onto the replacement rack, as most remanufactured steering racks do not come with this piece?
Haven't had it installed yet - I noticed the same thing for the years, I think they do that to keep track what year car the core came off of. The actual part is all the same from BMW.
Mine didn't come with that little plastic cap either, I guess you just swap it over?
I doubt mine will ever see a track so I didn’t worry about changing out the bolts for new, just torqued them down as normal. I do change the crush washers on everything and also there was a special banjo bolt on one of the hoses that had some sort of valve or screen filter in it that I changed as well.
Hardest part for me was getting all of the air out...took like 10 starts and wheel turning cycles. Had to wait like 10 mins between each so the bubbles would come to the top of the reservoir each time. The PS pump was really unhappy for the first couple for sure.
How has the BBB steering rack been behaving? I need to replace my rack too and I'm considering ordering this one as well.
