1 - 2 of 2 Posts
When you just want ouside air blowing in the car what settings do you use? I will have the fan on with the cabin setting at 65 and an ouside air temp of 70 and heat seems to be blowing in. Mine is an 02 M5.
Make sure the air distribution wheel ( between the center vents) is set to cold, 3 blue dots should be showing. On the right side of the climate control there is a button that switches between outside air and recirc air. It also has an auto setting (A) which basically blows outside air unless the car senses polluted air; it will then switch to recirc. Hope that helos.
1 - 2 of 2 Posts
