using the FOB, the windows roll up, and the mirrors fold up.
once you open the door, the mirrors fold back down.
cherrsagai
cable off ebay, windows 7 laptop, and some help from the web.
Some good info here:
Vehicle Coding
Anyway someone can post a diy?
cherrsagai
Vehicle Coding
Thanks for sharing, a lot of good info here:applause::1:Start here:
Getting Started with Coding your car
Things I learned:
window 7 32bit NOT 64 bit.
OBD Cable purchased from ebay:
BMW INPA Ediabas K DCAN | eBay
Get the latest FTDI Drivers for the OBD Cable:
http://www.ftdichip.com/Drivers/CDM/CDM20812.zip
Change the settings on the following files.
Run in XP Compatibility mode.
Run as administrator
C:\NCSEXPER\BIN\NCSEXPER.exe
C:\EDIABAS\Bin\EbasX32.exe
C:\INPA\BIN\INPA.exe
(Navigate to the file, right click, properties, advanced, then compatibilty tab.)
**when coding - make a backup of each file before you start to edit it**
If you want folding mirrors, make sure you also program the windows.
Folding Mirrors:
Where: KGM
Item: BEIKLAPPEN_B_KOMFORTSCHL
Change to: aktiv
Roll windows up
Where: CAS
Item: KOMFORTSCHLIESSUNG_FB
Chage to: aktiv
Remove legal notice from NAV.
Where: CAPPL
Item: LEGAL_DISCL
Change to: nicht_aktiv
Google Spreadsheet with TONS of other items.
https://spreadsheets.google.com/ccc...1LxgvNCbJ_ODykdw&hl=en&authkey=CNPs2ucN#gid=0
