1 - 15 of 15 Posts
Hi Guys,
Just want to share some experience on my Brembo Front 8 Piston and Rear 4 Piston.
I took my car to the track. I stopped the car everytime after 3-4 laps. Total probably 10-12 laps.
After the session, everytime I brake, it makes very loud sound on the brake.
I checked to the dealer. The results, all the front pads (total 8 pcs) are cracking. Rear was okay. I'll post some pics.
Any idea?
Clearly you've exceeded the maximum operating temperature of those pads. My suggestion is to run different pads on the street from the track.
Centric makes an excellent low-dust, low noise pad for that caliper - the Posi-Quiet Semi-Metallic. It was designed for the Audi RS4, so it comes with an integrated brake wear sensor and harness. You can either cut off the sensor wire, or you can splice a BMW sensor harness into it and retain the dash warning for low brake pads. These pads are far less expensive than the street pads sold by Brembo for your BBK.
For the track, I suggest the Ferodo DS2500. In a strange departure from standard practice, you will need to purchase TWO boxes of Ferodo pads to fill both calipers. Each box only contains four pieces and you need a total of eight pieces.
These pads can be purchased on-line here: http://store.zeckhausen.com/catalog/index.php?cPath=82_83
When swapping back and forth between street and track pads, follow these instructions to avoid brake judder issues: http://www.zeckhausen.com/avoiding_brake_judder.htm. If you have any questions, email us at [email protected] or give us a call. We'll be happy to help.
^^^^^ As always, great info ^^^^^
Cheers ///
Remember, tell Brembo you broke the pads in BEFORE you went to the track....so they won't hassel you about your return....funny this happened, did you have racing tires on the car ??
Gustav,
I think mine are street pads. Several years ago, I did try my E-46 M3 on the track. It was also equipped with Street pads, Front 4/6 Piston (not sure, forgot already), Rear 4 Piston. I did more laps, and I pushed it even harder than this time. No problem at all. :confused: Very weird. Maybe I should change it to race pads.
Wow... Great info. Really appreciate it.
Any idea the disadvantage if I use track pads on regular or street driving?
I rarely go the track, probably once a year, only on some special events.
Weird thing, my friend gasterus (active member on this board also) was driving his M6 at the same time. Same laps, we were probably neck to neck. I know his car was much faster than mine ;) His car was fine. No problem at all with stock M6 brake system. I also tried his car, and I felt the Brembo's are much better.
Isn't Brembo should be more reliable than the stock M6 brake? Just curious.
Thanks....
Listen to Dave.
Also bed your pads in next time.
And for your friend, you could just be not as good as a driver. Brakes are NOT meant to stop a car on a race track, they are meant to keep the car balanced going around the race track.
Think of the track as a river and you must flow through it, not try to attack it.
I thought that the Brembo kit for our cars was front calipers 6 pistons and rears 4 piston? That's what I have and at time of purchase there was no other set up. These are the monoblok aluminum calipers right?
Based on the pad photos, HS_01 has the GT8 8-piston front calipers. It uses 4 pads per caliper. These are the same calipers used on the Audi RS4.
Here's a photo I took of this same caliper, just prior to installing the Gran Turismo kit on a BMW X5:
Listen to Dave.
Yup, I was tracking my car with HS_01 that day....pretty hot day maybe around 100 degrees F. I guess i'm not pushing my car hard enough...kind of squeezing my brakes rather than slamming it, I'm trying to avoid frying my stock pads cause I have read critics on the poor performance of our stock pads. However, both of our cars are running very high oil temperatures after 4-5 laps, and has it pit in and cool down our engine before another lap sessions. Great track experience but ends up with plenty of maintainence costs for HS_01.
Are you tracking the car in Indo or over here in the States? I've heard the track outside JKT is not bad.
Listen to Dave.
Just sharing with you that I'm not a beginner on the race track. I've been attending several driving school experience.
Last year I went to Ferrari Piloti Driving experience in Zhu Hai (China). I drove the 599GTB, F430, F430 Scuderia for two days on the track.
Well, no offense, at least I know how to brake on the track. :cheers:
Discussion Starter #15
We were tracking the car in Indonesia which called Sentul International Circuit. The track layout was not bad. Just the asphalt wasn't too good.
I think track in States have better maintanence. I tried California Speedway and Willow Springs.
1 - 15 of 15 Posts
