1 - 12 of 12 Posts
I have a 2006 E60 M5 (with 54,000 miles on it). I'm the 2nd owner of the car, and have put on about 3,000 miles since buying it. Car runs great; no problems, complaints, or issues whatsoever.
Was thinking about getting some preventive maintenance done (e.g., fluid change service).
It's due for an oil change service, so I'm definitely having that done ($180 for oil, filter, and labor).
What other fluids should I have changed?
I'm thinking:
  • Transmission fluid
  • Differential fluid
  • Brake fluid
  • Engine coolant
  • SMG hydraulic fluid
Are these the main fluids that I should have done, or is this a bit over board?
Thanks in advance! :cheers:
Edit:
  • Brake fluid
  • SMG pump relay
  • Fuel filter
Mine has 56k and I'll have the samething done except the coolant. In addition, I'll replace the fuel filter as well.
Reactions: DocsV10
I think I'll add replacing the fuel filter to my list as well :cheers:
Reactions: 2Live4
not over board. You should establish a baseline if you haven't already.
I changed oil, smg, transmission, diff, brake, power steering, coolant 2wks after I took ownership.
google mike miller's old school maintenance
you can either buy the fluids and go to texas track works and have them do it all except the SMG. or go to UBS in Addison and have them do everything. I had it all done at UBS in Addison. They are a lot closer to me.
i don't think it's overboard at all. not sure your driving conditions there, but fluid changes are always good to establish a baseline as mentioned. i did all of this when i first bought my car even after the dealership said it's not due. sounds crazy but i'm anal like that.
Reactions: DocsV10 and Benzin
Have your spark plugs ever been changed? They are due at 37K miles, along with the engine air filters. Tranny and Diff fluid are due every 3rd oil change. Brake fluid is due every 2 years. Coolant and SMG Hyd fluid might be overkill, IMO. BMW coolant is "lifetime" which might equate to 100K miles. I would put SMG Hyd fluid in the same "lifetime" category.
Thanks for the info!
I spoke to B over at UBS and I'm definitely going there. Had a really good experience with them in the past!
I changed the plugs about 1,000 miles ago (roughly at ~53,000 miles).
Air filters are fine, since I have the AFE drop-in filters. I just clean them periodically; other than that, pretty much maintenance free.
Tranny and diff are a must; I may pass on the engine coolant though.
Thanks for the advice!
Doesn't sound crazy at all! I'm pretty OCD like that as well lol... Just trying to get some reassurance and security knowing that I've done some preventive maintenance.
Owning an M5 is an absolute joy, but an expensive hobby! :M5launch:
SMG pump relay in the ecu boxx... Cheap, easy DIY..
Also remember there isnt an exact way to change the hydraulic fluid, and you will have to de-pressurize the system before opening to drain, and to bleed after filling.. There is no bmw recommendation to change the smg fluid out, but some members have thought it would be better to change it out.
DinanS2+ e60m5 6MT, s38b38 e28m5 TT/ST3, e30 TT/ST4
I although not essential, I would add/insepct to the list:
wheel bearings
control arms
diff mounts
Our Beast are heavy and all the front end bits tend to wear out around your mileage -- at least mine did.
Reactions: DocsV10
1 - 12 of 12 Posts
